Telepresence drops after adding voice bridge
Aug 23rd, 2013
     It is begining to happen quite often now. As soon as a voice port is added to our telepresence for WebEx users the system crashes. What is causing this? It happened several times this morning and 3 times last wee.
Martin Koch Sun, 08/25/2013 - 14:56
  • Red, 2250 points or more
If you could tell us a bit more about your deployment, what components are involved, what
software versions are used, how does the exact call scanario look like.
If you do not feel that you get a proper answer and you have a cisco service contract consider
escalating the case as a Serivce request (you can do that with the menu on the right top) to Cisco TAC.
Any how please keep us updated what the issue was and how you solved it.
Please remember to rate helpful responses and identify helpful or correct answers.
