Warning message
ISSU to NX-OS 6.2(2) fails. OTV error
Answered Question
Aug 23rd, 2013
Just tried upgrading 2 of the 4 chassis' I have and it went horribly wrong. Well not really, it just failed with almost no packet drops.
This is a OTV setup across two sites. I did a ISSU upgrade on 2 chassis simultanuously (1 in each site) and got exactly the same error on both.
2013 Aug 23 20:45:28 glsdswn7k001 %$ VDC-1 %$ %PLATFORM-2-MOD_REMOVE: Module 6 removed (Serial number JAFXXXX)
2013 Aug 23 20:45:28 glsdswcore001 %$ VDC-2 %$ last message repeated 1 time
2013 Aug 23 20:45:28 glsdswotv001 %$ VDC-3 %$ last message repeated 1 time
2013 Aug 23 20:49:23 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:49:54 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:50:25 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:50:56 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:51:27 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:51:58 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:52:29 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
2013 Aug 23 20:53:00 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
Resetting boot variables. Please wait.
2013 Aug 23 20:53:32 glsdswn7k001 %$ VDC-1 %$ %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id 0xFFFFFFFF).
[####################] 100%
2013 Aug 23 20:53:47 glsdswn7k001 %$ VDC-1 %$ %PLATFORM-2-MOD_REMOVE: Module 6 removed (Serial number JAFXXXX)
2013 Aug 23 20:53:47 glsdswcore001 %$ VDC-2 %$ last message repeated 1 time
2013 Aug 23 20:53:47 glsdswotv001 %$ VDC-3 %$ last message repeated 1 time
Failure recovery action::
"Standby will be rebooted to force netboot and image download".
Install has failed. Return code 0x4093001E (Standby failed to come online).
Please identify the cause of the failure, and try 'install all' again.
The logs show the following:
2013 Aug 23 20:47:10 glpdswn7k002 %PLATFORM-2-MOD_REMOVE: Module 6 removed (Serial number JAFXXXX)
2013 Aug 23 20:49:21 glpdswn7k002 %BOOTVAR-5-NEIGHBOR_UPDATE_AUTOCOPY: auto-copy supported by neighbor supervisor, starting...
2013 Aug 23 20:50:56 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:50:56 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 8979) has finished with error code SY
SMGR_EXITCODE_SYSERR (1).
2013 Aug 23 20:51:27 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:51:27 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9132) has finished with error code SY
2013 Aug 23 20:51:58 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:51:58 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9349) has finished with error code SY
2013 Aug 23 20:52:29 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:52:29 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9384) has finished with error code SY
2013 Aug 23 20:53:00 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:53:00 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9402) has finished with error code SY
2013 Aug 23 20:53:31 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:53:31 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9435) has finished with error code SY
2013 Aug 23 20:54:02 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:54:02 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9623) has finished with error code SY
2013 Aug 23 20:54:33 glpdswn7k002 %SYSMGR-STANDBY-2-CONVERT_FUNC_FAILED: Conversion function failed for service "otv" (error-id
0xFFFFFFFF).
2013 Aug 23 20:54:33 glpdswn7k002 %SYSMGR-STANDBY-3-SERVICE_TERMINATED: Service "otv" (PID 9769) has finished with error code SY
2013 Aug 23 20:55:00 glpdswn7k002 %SYSMGR-3-SERVICE_TERMINATED: Service "installer" (PID 26230) has finished with error code SYS
MGR_EXITCODE_FAILURE_NOCALLHOME (20).
2013 Aug 23 20:55:02 glpdswn7k002 %PLATFORM-2-MOD_REMOVE: Module 6 removed (Serial number JAFXXXX)
2013 Aug 23 20:57:21 glpdswn7k002 %BOOTVAR-5-NEIGHBOR_UPDATE_AUTOCOPY: auto-copy supported by neighbor supervisor, starting...
2013 Aug 23 20:59:03 glpdswn7k002 %MODULE-5-STANDBY_SUP_OK: Supervisor 6 is standby
Any idea anyone?
Correct Answer by pille1234 about 3 years 11 months ago
Did you read the release notes? It clearly states
OTV
Any upgrade from an image that is earlier than Cisco NX-OS Release 6.2(2) to an image that is Cisco NX-OS Release 6.2(2) or later in an OTV network is disruptive. When you upgrade from any previous release, the OTV overlay needs to be shut down for ISSU to operate.
For more details, see the "Preparing OTV for ISSU to Cisco NX-OS 5.2(1) or Later Releases in a Dual-Homed Site" section in the Cisco Nexus 7000 Series NX-OS OTV Configuration Guide.
Regards Pille
Overall Rating: 5 (2 ratings)
EDC Operations Fri, 08/23/2013 - 12:29
Thought I'd dump the config of the OTV VDC here as well...
version 6.1(4)
hostname lpdswotv002
feature tacacs+
cfs eth distribute
feature ospf
feature otv
feature udld
feature interface-vlan
feature hsrp
feature lacp
feature dhcp
feature bfd
username admin password 5 kk  role vdc-admin
ip domain-lookup
ip access-list ALL_IPs
  10 permit ip any any
mac access-list ALL_MACs
  10 permit any any
ip access-list HSRP_IP
  10 permit udp any 224.0.0.2/32 eq 1985
  20 permit udp any 224.0.0.102/32 eq 1985
mac access-list HSRP_VMAC
  10 permit 0000.0c07.ac00 0000.0000.00ff any
  20 permit 0000.0c9f.f000 0000.0000.0fff any
arp access-list HSRP_VMAC_ARP
  10 deny ip any mac 0000.0c07.ac00 ffff.ffff.ff00
  20 deny ip any mac 0000.0c9f.f000 ffff.ffff.f000
  30 permit ip any mac any
vlan access-map HSRP_Localization 10
        match mac address HSRP_VMAC
        match ip address HSRP_IP
        action drop
vlan access-map HSRP_Localization 20
        match mac address ALL_MACs
        match ip address ALL_IPs
        action forward
vlan filter HSRP_Localization vlan-list 1500-1509,1600-1620
snmp-server user admin vdc-admin auth md5 0x4789e0334323ad58a117a4a94b priv 0x478934334338a117a4a94b localizedkey
rmon event 1 log trap public description FATAL(1) owner [email protected]
rmon event 2 log trap public description CRITICAL(2) owner [email protected]
rmon event 3 log trap public description ERROR(3) owner [email protected]
rmon event 4 log trap public description WARNING(4) owner [email protected]
rmon event 5 log trap public description INFORMATION(5) owner [email protected]
ip routing event-history general size medium
ip route 0.0.0.0/0 10.236.0.13
vrf context management
  ip route 0.0.0.0/0 10.236.16.1
vlan 1,14,1500-1509,1600-1620
vlan 14
  name DC1_OTV_Site_VLAN
otv site-vlan 14
service dhcp
ip dhcp relay
interface Vlan1
interface port-channel6
  description OTV Internal Interface
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 14,1500-1699
interface Overlay1
  otv join-interface Ethernet7/1
  otv extend-vlan 1500-1699
  otv use-adjacency-server 10.236.0.1 10.237.0.10 unicast-only
  no shutdown
  description OTV Join Interface
  rate-mode dedicated force
  mtu 9216
  no ip redirects
  ip address 10.236.0.14/30
  no ipv6 redirects
  ip ospf network point-to-point
  no ip ospf passive-interface
  ip router ospf 1 area 0.0.0.0
  ip ospf bfd
  no shutdown
interface Ethernet7/2
  switchport
  channel-group 6 mode active
  no shutdown
interface Ethernet7/3
interface Ethernet7/4
interface Ethernet7/5
interface Ethernet7/6
interface Ethernet7/7
interface Ethernet7/8
interface Ethernet7/9
  switchport
  no shutdown
interface Ethernet7/10
interface Ethernet7/11
interface Ethernet7/12
interface Ethernet7/13
interface Ethernet7/14
interface Ethernet7/15
interface Ethernet7/16
interface Ethernet7/17
interface Ethernet7/18
interface Ethernet7/19
interface Ethernet7/20
interface Ethernet7/21
interface Ethernet7/22
interface Ethernet7/23
interface Ethernet7/24
interface Ethernet7/25
interface Ethernet7/26
interface Ethernet7/27
interface Ethernet7/28
interface Ethernet7/29
interface Ethernet7/30
interface Ethernet7/31
interface Ethernet7/32
interface mgmt0
  ip address 10.236.16.23/24
cli alias name wr copy run start
line console
  terminal width  128
line vty
router ospf 1
  router-id 10.236.16.23
  log-adjacency-changes
  passive-interface default
otv site-identifier 0x10
ip arp inspection filter HSRP_VMAC_ARP vlan 1500-1699
Correct Answer
pille1234 Sat, 08/24/2013 - 05:18
  • Bronze, 100 points or more
OTV
Regards Pille
EDC Operations Sat, 08/24/2013 - 05:30
Hi Pille,
I actually did read it but apparently not thoroughly enough. Thanks for pointing this out.
I'll have another go.
Related Content
Trending Topics: Other DC Subjects
