SalesForce Integration - Need UCCX ?
Aug 23rd, 2013
I am bit confused here. I know you can accomplish srceen pop-up based on ANI using CAD and http triggers and that you need Premium license as HTTP commands are not possible in CAD with Enhanced licenses, right ? However, here is the situation:
What if the only requirements are:
-1) Being able to click-2-call from salesforce
-2) WHen a customer calls in open up their salesforce account ?
     Call comes in from an Autto attendant that rings 10 phones at the same time.. ("agents")
I've been taking a look at "Cisco Unified CallConnector for Salesforce.com" and it is not quite clear if UCCX is mandatory. To tell you the truth I don't need to do any IVRs, ACD groups or anything like that. The customer only wants a basic salesforce integration to start with...
In case of UCCX being mandatory why would I use it and what kind of license would I need ?
Joan
david.macias Fri, 08/23/2013 - 13:09
  • Blue, 1500 points or more
I can't speak for the UCCX piece, but I can tell you that click to call doesn't work well with CAD and a Cisco Phone.  This was with UCCE and CAD by the way.
david
Pranjol Saikia Thu, 10/06/2016 - 02:38
For any custom 3rd party Salesforce (SFDC) integration requirements please reply.
Insert data into SFDC ( Salesforce) based on data entered by caller in Cisco CVP IVR / UCCX IP IVR
Incomming Caller Details popup in SFDC Screen
Display incomming caller data from SFDC in Cisco Agent Finesse Screen
Initiate outbound call ( Click 2 Dial) from SFDC Screen
Call Warapup for inbound/outbound calls in SFDC Screen - SFDC Activity
Call Warapup for inbound/outbound calls in SFDC Screen - SFDC Case
Pranjol
