ASA 5512-X no int vlan command!?
Aug 23rd, 2013
I don't have much experience yet with ASAs but I thought the int vlan command should be available? It's an ASA 5512-X with IOS 8.6(1)2, should I upgrade to the newest 9 version? Also, there are rj45 interfaces and SFP interfaces which are numbered Gi0/0 -5 and Gi1/0 - 5, how do I tell what numbers correspond to what interfaces?  Thanks
Overall Rating: 5 (1 ratings)
Marvin Rhoads Fri, 08/23/2013 - 20:30
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
"int vlan" is specific to the 5505 which has an integrated switch. The 5510 and higher use a subinterface and vlan command within the subinterface config mode. See the configuration guide section here:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/interface_start.html#wp1082576
Rear panel ports are numbersed as described in the hardware installation guide here:
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/5500xguide/asa_overview.html#wp1069960
I don't have one in front of me but seem to recall they also have printed designations on the physical unit if you look closely.
