TAG problem in OSPF-BGP
Anand Solgama
I create a LAB and try to apply set tag and match tag for loop prevention.
I used R1 ,R2,R3 BGP and R2-R4 ,R3-R5 OSPF now I want to set tag on R2 side for OSPF so that I can match it and deny it on R3 side!!!!
I have attached my lab with this post.
I am pasting R2 and R3 config here :
R2::::
router ospf 1
log-adjacency-changes
redistribute bgp 200 subnets
network 192.168.1.0 0.0.0.255 area 1
router bgp 200
no synchronization
bgp log-neighbor-changes
network 200.200.200.0
redistribute ospf 1 match internal external 1 external 2 route-map TAG
neighbor 200.200.200.1 remote-as 100
no auto-summary
no ip http server
no ip http secure-server
route-map TAG permit 10
set tag 50
R3:::::::::
router ospf 1
redistribute bgp 300 subnets route-map TAG
network 192.168.2.0 0.0.0.255 area 1
distribute-list route-map TAG in
router bgp 300
no synchronization
network 200.200.201.0
neighbor 200.200.201.1 remote-as 100
no auto-summary
no ip http server
route-map TAG deny 10
match tag 50
route-map TAG permit 20
so my problem is why R2's OSPF not stoping at R3 where I used match tag???
Anand,
The distribution-list technique can be really hard to maintain in a real life network as the list needs to be modified every time a new prefix is added somewhere in the network. The route-map (set tag/match tag) technique is really easy to maintain.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
7 Replies 7
Rolf Fischer
Level 9
Level 9
Hi Anand,
you cannot use a  route-map with set tag when redistributing an IGP into BGP, see "Table 2" in
Route-Maps for IP Routing Protocol Redistribution Configuration
When doing so, may IOS display a message like:
% "TAG" used as redistribute ospf into bgp route-map, set tag not supported
Hope that helps
Rolf
Thanks I also saw this so I also used distribution-list to match route-map
Anand,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I tried like this ....
R2:::::
router eigrp 1
redistribute ospf 1 metric 30000 1 255 255 1500 route-map TAG
auto-summary
router ospf 1
redistribute eigrp 1 subnets
set tag 50
R3:::::
router eigrp 1
auto-summary
router ospf 1
redistribute eigrp 1 subnets route-map TAG
no ip http server
match tag 50
sometimes there is an option after redistribute command TAG but sometimes dont so I think we should use route-map   This is working now my R2 OSPF routes not showing in R5
Thanks 4 help happy now
Is there any way to check TAG is working or not other than check in route table ???
Harold Ritter
Hi Anand,
As Rolf mentioned, you can't set tag in BGP. The equivalent of tag in BGP would be community. Generally though, when you do mutual redistribution between BGP and an OSPF at multiple point in the network and you to make sure that there will not be loops, you should rather tag the routes when redistributing from BGOP to OSPF and deny these routes when redistributing back from OSPF to BGP.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks again ,but I couldnt do it properly on EIGRP to OSPF as well
Any material ???so I can learn my self ,I checked some sites but tuff examples
Hi Anand,
The same would apply for EIGRP to OSPF redistribution. You would set a specific tag when redistributing from EIGRP to OSPF and then deny routes that match that same specific tag when redistributing from OSPF to EIGRP.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
