CUE greetings error for Multi site
nithin louis
I have a multi site(Site A & site B) IP Telephony set up with Call manger Express and voice mail for CUE.
I have forwarded the calls to voice mail when no answer and busy.
Its working fine when an external call comes and if the user is busy or no answer its going to voice mail and fine with internal calls.
But when site A user tries to make calls to Site B  if the user is busy or no answer its going to voice mail but we cannot hear the greetings after the ring its blank and as we can see that its going to the Voicemail number.
Do I need to enable anything on unity express for this?
Thanks in advance
Nithin Louis.
15 Replies 15
ronpatel
Level 8
Level 8
Is it happening in other way call . I mean if you call from site b to site a phone , what is the status for other way call
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
Yes both side we are facing the same issue.
Site A
dial-peer voice 7777 voip
description ***SIP dial peer- Unity express***
destination-pattern 777.
session protocol sipv2
session target ipv4:192.168.0.3
dtmf-relay sip-notify
voice-class codec 183
no vad
voice class codec 183
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
dial-peer voice 767676 voip
description ***Dial-Peer to Site B***
destination-pattern 4[1,5]..
translate-outgoing called 321
session target ipv4:192.168.32.100
dtmf-relay h245-alphanumeric
no vad
Site B
dial-peer voice 6666 voip
description "Unity Express Dial Peer"
destination-pattern 666.
session target ipv4:192.168.32.101
no vad
dial-peer voice 1 voip
destination-pattern 913..
translate-outgoing called 123
session target ipv4:192.168.0.2
no vad
Nithin Louis
Hi ,
When I am calling from Site A(Extn.100) to Site B (Extn.500) and Site B's phone is offline then Site A 's phone can hear the greetings from CUE.But When Site B 's phone is on line then the same issue is happening like cannot hear the greetings.
We are connected the 2 site using Site to site VPN with sufficient bandwidth.
Thanks in advance
Nithin Louis.
Any update guys....
Nithin Louis.
Collect the following for one of these calls:
debug h225 asn1
debug h245 asn1
debug ccsip messages
Disable console logging and use a logging buffer:
no logging console
logging buffered 5000000
Then to view the log, do the following:
term len 0
show log
HI Brain ,
I have collected the logs.Please review the attached.
We made calls from Site A (Extn.1334) to site B (Extn. 112).
Thanks in advance
Nithin Louis.
Immediately after the initial setup is complete with CUE, the gateway is sending a Re-Invite setting the call to receive only:
Sep  5 19:37:45.582: //6288/78FCE004BFEF/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:6666@192.168.32.101:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.32.100:5060;branch=z9hG4bK5EC65C
To: <6666>;tag=dsc6941c0f
Date: Thu, 05 Sep 2013 19:37:45 GMT
Call-ID: 78FCE004-159911E3-BFF4CDF4-39C004D8@192.168.32.100
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2029838340-0362353123-3220164084-0968885464
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1378409865
Contact: <17101334>
Call-Info: <192.168.32.100:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Diversion: <112>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 208
v=0
o=CiscoSystemsSIP-GW-UserAgent 656 9782 IN IP4 192.168.32.100
s=SIP Call
c=IN IP4 192.168.32.100
t=0 0
m=audio 18282 RTP/AVP 0
a=recvonly
a=rtpmap:0 PCMU/8000
a=ptime:20
Seems like CUE just interprets that as inactive media:
Sep  5 19:37:45.590: //6288/78FCE004BFEF/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 INVITE
Content-Length: 128
Contact: <6666>
Call-Info: <192.168.32.101:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 78FCE004-159911E3-BFF4CDF4-39C004D8@192.168.32.100
v=0
o=CUE 3641731 3 IN IP4 192.168.32.101
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 20856 RTP/AVP 0
This results in silence for 14 seconds until the user hangs up:
Sep  5 19:37:59.178: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          protocolIdentifier { 0 0 8 2250 0 4 }
          callIdentifier
            guid '9D737A05157711E39EE0A3E57C8B164F'H
        h245Tunneling TRUE
Sep  5 19:37:59.182: //6288/78FCE004BFEF/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:6666@192.168.32.101:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.32.100:5060;branch=z9hG4bK5EE1346
Max-Forwards: 70
Timestamp: 1378409879
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=0,OS=0,PR=2,OR=161,PL=0,JI=0,LA=0,DU=13
Content-Length: 0
So we need to find out what is causing that recvonly event.
At the beginning of the call, we see the inbound and outbound OpenLogicalChannel but I don't see any OpenLogicalChannelAcks.  I wonder if that may be the problem.
Can you post your full configs?
Hi ,
Thanks for your quick reply.As requested please review the full configurationsd for Site A & Site B.
Nithin Louis.
It looks like your SiteB doesn't have an incoming voip dial-peer that these calls would match so they may be matching dial-peer 0 which is G.729 only.  Try adding this on SB to your first voip dial-peer:
incoming called-number .
Hi Brian,
I have added the incoming called-number . under the dial-peer voice 1 voip. But result is same
Thanks & Regards
Nithin Louis.
Can you re-attach a fresh copy of your config and the same debugs?
Hi Brian,
Please review the attahed files.
We are calling from extn. 1334 from site A to site B extn. 112
Nithin Louis.
Hi Brian,
Please note the below points..
Site A
CME Ip addres is : 192.168.0.2 & CUE is 192.168.0..3
Site B
CME IP addres is : 192.168.32.100 & CUE is 192.168.32.101
Nithin Louis.
Michael Gerrard
It smells like routing to me, with no-way-voice. Ensure reachability to the IP address of the CUE module IP address from everywhere.
Also, I'd add in incoming called-number . into your VoIP dial-peers to ensure that you don't hit dial-peer 0 when dialling between sites. CUE is obviously a bit funny about codec choices so best to end up using the right one.
Mike.
