Warning message
vlan can't connect each other and router can't ping the pc
Aug 26th, 2013
  • Silver, 250 points or more
hello sir, i had design a wireless network prototype using packet tracer, i had use device listed below :
Cisco 1841 Router = 1xunit
Cisco 2960 Switch = 1xunit
Linksys Wireless Router(WRT 300N) = 2xunit
Laptop = 5unit(vlan 10=2unit, vlan 20=3unit)
in the Cisco 1841 Router i had implement inter vlan and eigrp as routing protocol , in the Cisco 2960 Switch i had implement the vlan10 and vlan 20...
and i had a problem because the laptop on each vlan can ping the Cisco 1841 Router but the Cisco 1841 Router can't ping the laptop on each vlan and also the wireless router can't ping for each other
p/s :- someone can check my configuration?? i need to know what is my fault. tell me if you want to check my packet tracer save file
Posted by WebUser ???? ?????????? from Cisco Support Community App
Scott Fella Mon, 08/26/2013 - 05:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Your vlan interfaces up/up and your trunking to the switch?
fb_webuser Mon, 08/26/2013 - 07:33
Current configuration : 1261 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname S2
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
description Trunk Link
switchport mode trunk
duplex full
interface FastEthernet0/2
switchport access vlan 20
switchport mode access
interface FastEthernet0/3
switchport access vlan 10
interface FastEthernet0/4
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip default-gateway 192.168.1.1
