error message on VSS
Hi All,
I would like to ask if you have see following error message and if it is realated to problem below..
Aug 24 18:15:56 core.schmid.local 753: Aug 24 18:15:55: %FIB-2-FIBDISABLE: Fatal error, slot 41/0 (41): XDR disabled
At the time of the performance problems was on active switch 1 switch We have switched to Switch 2 8:24
Changeover took place via the command: redundancy force-switchover
On closer analysis, I have found that Switch 2 has not booted, but it was the SSO failover a problem with the module 9 on Switch 2
The switch has reported this at 8:29 clock and then made the module normally. After automatic. Reload the module were all the services accessible again.
Note: Module 9 = WS-X6904-40G = Terminals our Data Center Switches -> Shortly after entering the switchover all connections were interrupted to the Data Center.
Aug 26 08:24:01: %LINK-3-UPDOWN: Interface Port-channel251, changed state to down
Aug 26 08:24:02: %ARP-3-STCKYARPOVR: Attempt to overwrite Sticky ARP entry: 192.168.30.36, hw: 001a.647a.d77a by hw: 001a.647a.d77c
Aug 26 08:24:02: %C6KPWR-4-PSOK: power supply 1 turned on.
Aug 26 08:24:02: %C6KPWR-4-PSOK: power supply 2 turned on.scp_dnld_stdby_disable, No instance for CHILISLC_PROCESSOR found slot 9
Aug 26 08:24:02: %OIR-3-SOFT_RESET_SSO: Module 9 is being soft reset as a part of switchover error recovery
Aug 26 08:24:02: %C6KENV-4-ADJACENT_SLOTS_EMPTY: Two adjacent slots of module 5 might be empty. Airdams must be installed in these slots to be NEBS compliant
Aug 26 08:24:03: %C6KENV-4-ADJACENT_SLOTS_EMPTY: Two adjacent slots of module 7 might be empty. Airdams must be installed in these slots to be NEBS compliant
Aug 26 08:24:03: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.111.7 Port 514 started - CLI initiated
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/3, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/4, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/5, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/6, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/7, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/8, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/9, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/10, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/11, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/12, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/13, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/14, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/15, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/16, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/17, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/18, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/19, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/20, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/21, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/22, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/23, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/24, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/1, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/2, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/3, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/4, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/5, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/6, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/7, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/8, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/9, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/10, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/11, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/12, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/13, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/14, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/15, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/16, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/17, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/18, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/19, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/20, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/21, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/22, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/2/23, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/5, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/6, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/9, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/10, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/13, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/14, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/17, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/9/18, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/3, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/4, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/5, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/6, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/7, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/8, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/9, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/10, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/11, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/12, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/13, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/14, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/15, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/16, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/17, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/18, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/19, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/20, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/21, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/22, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/23, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/24, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/1, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/2, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/3, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/4, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/5, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/6, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/7, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/8, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/9, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/10, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/11, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/12, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/13, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/14, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/15, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/16, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/17, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/18, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/19, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/20, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/21, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/22, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/2/23, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/5, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/6, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/9, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/10, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/13, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/14, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/17, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/9/18, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/2, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/3, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/3, changed state to up
Aug 26 08:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/4, changed state to up
Aug 26 08:24:03: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/5, changed state to up
Aug 26 08:24:04: %VSDA-3-LINK_DOWN: Interface Gi2/1/48 is no longer dual-active detection capable
Aug 26 08:24:04: %VSDA-3-LINK_DOWN: Interface Gi2/2/24 is no longer dual-active detection capable
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/5, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/6, changed state to up
Aug 26 08:24:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/7, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/7, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/8, changed state to up
Aug 26 08:24:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/9, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/9, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/10, changed state to up
Aug 26 08:24:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/11, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/11, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/12, changed state to up
Aug 26 08:24:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/13, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/13, changed state to up
Aug 26 08:24:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/14, changed state to up
Aug 26 08:24:05: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/15, changed state to up
Aug 26 08:24:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/15, changed state to up
Aug 26 08:24:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/16, changed state to up
Aug 26 08:24:05: %OIR-6-INSREM: Switch 1 Physical Slot 1 - Module Type LINE_CARD removed
Aug 26 08:24:05: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/17, changed state to up
Aug 26 08:24:05: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/18, changed state to up
Aug 26 08:24:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/17, changed state to up
Aug 26 08:24:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/18, changed state to up
Aug 26 08:24:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/19, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/20, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/20, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/21, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/22, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/22, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/23, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/24, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/24, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/1, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/2, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/2, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/3, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/4, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/4, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/5, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/6, changed state to up
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/7, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/6, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/7, changed state to up
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/8, changed state to up
Aug 26 08:24:06: %OIR-6-INSREM: Switch 1 Physical Slot 2 - Module Type LINE_CARD removed
Aug 26 08:24:06: %LINK-3-UPDOWN: Interface Port-channel250, changed state to down
Aug 26 08:24:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/9, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/10, changed state to up
Aug 26 08:24:07: %OIR-6-INSREM: Switch 1 Physical Slot 5 - Module Type LINE_CARD removed
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/11, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/12, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/12, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/13, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/14, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface Port-channel220, changed state to down
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface Port-channel210, changed state to down
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/14, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/15, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/16, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/17, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/18, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/16, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/17, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/18, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/19, changed state to up
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/20, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/20, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/21, changed state to up
Aug 26 08:24:07: %OIR-6-INSREM: Switch 1 Physical Slot 9 - Module Type LINE_CARD removed
Aug 26 08:24:07: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/22, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/22, changed state to up
Aug 26 08:24:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/23, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel20, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel21, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel22, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel23, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel24, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel25, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel26, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel27, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel28, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel29, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel30, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel31, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel32, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel33, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel34, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel35, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel36, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel37, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel38, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel39, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel40, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel41, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel42, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel43, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel44, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel45, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel46, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel47, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel48, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel49, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel50, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel51, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel52, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel53, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel54, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel55, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel56, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel57, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel58, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel59, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel60, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel61, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel62, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel63, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel64, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel65, changed state to up
Aug 26 08:24:08: %LINK-3-UPDOWN: Interface Port-channel66, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel20, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel21, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel22, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel23, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel24, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel25, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel26, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel27, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel28, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel29, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel30, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel31, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel32, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel33, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel34, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel35, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel36, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel37, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel38, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel39, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel40, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel41, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel42, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel43, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel44, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel45, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel46, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel47, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel48, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel49, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel50, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel51, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel52, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel53, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel54, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel55, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel56, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel57, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel58, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel59, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel60, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel61, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel62, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel63, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel64, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel65, changed state to up
Aug 26 08:24:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel66, changed state to up
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/25, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/26, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/27, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/28, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/29, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/30, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/31, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/32, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/33, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/34, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/35, changed state to administratively down
Aug 26 08:24:08: %LINK-5-CHANGED: Interface GigabitEthernet2/1/37, changed state to administratively down
Aug 26 08:24:14: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.111.7 Port 514 started - reconnection
Aug 26 08:24:26: %HSRP-5-STATECHANGE: Vlan12 Grp 1 state Standby -> Active
Aug 26 08:24:30: %HSRP-5-STATECHANGE: Vlan33 Grp 1 state Standby -> Active
Aug 26 08:24:30: %HSRP-5-STATECHANGE: Vlan21 Grp 1 state Standby -> Active
Aug 26 08:24:30: %HSRP-5-STATECHANGE: Vlan35 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan90 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan50 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan13 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan34 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan31 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan114 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan120 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan46 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan115 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan40 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan44 Grp 1 state Standby -> Active
Aug 26 08:24:31: %HSRP-5-STATECHANGE: Vlan140 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan10 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan116 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan23 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan130 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan127 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan24 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan43 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan80 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan126 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan32 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan42 Grp 1 state Standby -> Active
Aug 26 08:24:32: %HSRP-5-STATECHANGE: Vlan41 Grp 1 state Standby -> Active
Aug 26 08:24:33: %HSRP-5-STATECHANGE: Vlan20 Grp 1 state Standby -> Active
Aug 26 08:24:33: %HSRP-5-STATECHANGE: Vlan92 Grp 1 state Standby -> Active
Aug 26 08:24:33: %HSRP-5-STATECHANGE: Vlan79 Grp 1 state Standby -> Active
Aug 26 08:24:33: %HSRP-5-STATECHANGE: Vlan111 Grp 1 state Standby -> Active
Aug 26 08:24:42: %HSRP-5-STATECHANGE: Vlan70 Grp 1 state Standby -> Active
Aug 26 08:24:42: %HSRP-5-STATECHANGE: Vlan11 Grp 1 state Standby -> Active
Aug 26 08:24:43: %HSRP-5-STATECHANGE: Vlan22 Grp 1 state Standby -> Active
Aug 26 08:25:44: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as ACTIVE by VSLP
Aug 26 08:25:44: %VSL-5-VSL_CNTRL_LINK: New VSL Control Link 2/5/4
Aug 26 08:25:46: %VSLP-5-VSL_UP: Ready for control traffic
Aug 26 08:25:54: %PFREDUN-6-ACTIVE: Standby initializing for SSO mode
Aug 26 08:26:36: %OIR-6-INSREM: Switch 1 Physical Slot 5 - Module Type LINE_CARD inserted
Aug 26 08:26:37: %QOS-3-HA_BULK_SYNC_BEFORE_TIMEOUT: QOS-HA-BLK-SYNC-PROCESS: Failure in completing bulk sync before timeout
Aug 26 08:26:45: %DIAG-6-RUN_MINIMUM: Switch 1 Module 5: Running Minimal Diagnostics...
Aug 26 08:27:00: %DIAG-6-DIAG_OK: Switch 1 Module 5: Passed Online Diagnostics
Aug 26 08:27:02: %VSLP-5-VSL_UP: Ready for data traffic
Aug 26 08:27:02: %LINK-3-UPDOWN: Interface Port-channel251, changed state to up
Aug 26 08:27:02: %LINK-3-UPDOWN: Interface Port-channel250, changed state to up
Aug 26 08:27:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel251, changed state to up
Aug 26 08:27:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel250, changed state to up
Aug 26 08:27:02: %OIR-6-SP_INSCARD: Card inserted in Switch_number = 1, physical slot 5, interfaces are now online
*Aug 26 06:15:45.015: SW1_STBY: SP: Currently running ROMMON from S (Gold) region
Aug 26 06:26:33.695: %OIR-SW1_STBY-6-INSPS: Power supply inserted in slot 1
Aug 26 06:26:33.703: %C6KPWR-SW1_STBY-4-PSOK: power supply 1 turned on.
Aug 26 06:26:33.711: %OIR-SW1_STBY-6-INSPS: Power supply inserted in slot 2
Aug 26 06:26:33.711: %C6KPWR-SW1_STBY-4-PSOK: power supply 2 turned on.
Aug 26 06:26:35.703: %C6KENV-SW1_STBY-4-FANHPMODE: Switch 1 Fan-tray 1 is operating in high power mode
Aug 26 06:26:35.711: %FABRIC-SW1_STBY-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
Aug 26 06:26:45.507: %DIAG-SW1_STBY-6-RUN_MINIMUM: Switch 1 Module 5: Running Minimal Diagnostics...
Aug 26 06:26:45.507: %CONST_DIAG-SW1_STBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestLoopback due to: the port is used as a VSL link.
Aug 26 06:26:45.507: %CONST_DIAG-SW1_STBY-6-DIAG_PORT_SKIPPED: Module 5 port 5 is skipped in TestLoopback due to: the port is used as a VSL link.
Aug 26 06:26:55.919: %CONST_DIAG-SW1_STBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestChannel due to: the port is used as a VSL link.
Aug 26 06:27:00.911: %DIAG-SW1_STBY-6-DIAG_OK: Switch 1 Module 5: Passed Online Diagnostics
Aug 26 06:27:14.234: %SSH-SW1_STBY-5-DISABLED: SSH 1.99 has been disabled
Aug 26 08:27:14: %SYS-SW1_STBY-6-CLOCKUPDATE: System clock has been updated from 08:27:14 MESZ Mon Aug 26 2013 to 08:27:14 MESZ Mon Aug 26 2013, configured from console by console.
Aug 26 08:27:16: %SSH-SW1_STBY-5-DISABLED: SSH 2.0 has been disabled
Aug 26 08:27:25: %SYS-SW1_STBY-5-RESTART: System restarted --
Cisco IOS Software, s2t54 Software (s2t54-IPBASEK9-M), Version 15.0(1)SY3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 19-Nov-12 19:22 by prod_rel_team
Aug 26 08:27:25: %SYS-SW1_STBY-6-BOOTTIME: Time taken to reboot after reload = 207 seconds
Aug 26 08:27:25: %SSH-SW1_STBY-5-ENABLED: SSH 2.0 has been enabled
Aug 26 08:27:26: %SYS-SW1_STBY-3-LOGGER_FLUSHED: System was paused for 00:01:30 to ensure console debugging output.
Aug 26 08:27:28: %C6KENV-SW1_STBY-4-ADJACENT_SLOTS_EMPTY: Two adjacent slots of module 5 might be empty. Airdams must be installed in these slots to be NEBS compliant
Aug 26 08:27:30: SW1_STBY: TTY0: timer_create_bg error
Aug 26 08:27:38: %VS_GENERIC-6-VS_HA_HOT_STANDBY_NOTIFY: Standby switch is in Hot Standby mode
Aug 26 08:27:38: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Aug 26 08:27:38: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Aug 26 08:27:38: %SSH-SW1_STBY-5-DISABLED: SSH 2.0 has been disabled
Aug 26 08:27:38: %SSH-SW1_STBY-5-ENABLED: SSH 2.0 has been enabled
Aug 26 08:27:38: %PFREDUN-SW1_STBY-6-STANDBY: Ready for SSO mode
Aug 26 08:27:47: %OIR-6-INSREM: Switch 1 Physical Slot 1 - Module Type LINE_CARD inserted
Aug 26 08:27:47: %OIR-6-INSREM: Switch 1 Physical Slot 2 - Module Type LINE_CARD inserted
Aug 26 08:27:47: %OIR-6-INSREM: Switch 1 Physical Slot 9 - Module Type LINE_CARD inserted
Aug 26 08:28:07: %C6KPWR-SW1_STBY-4-PSOUTPUTDROP: Power supply 1 output has dropped
Aug 26 08:28:07: %C6KPWR-SW1_STBY-2-PSFAIL: power supply 1 output failed.
Aug 26 08:28:07: %C6KPWR-SW1_STBY-4-PSREDUNDANTONESUPPLY: in power-redundancy mode, system is operating on one power supply.
Aug 26 08:28:10: %VSLP-3-VSLP_LMP_FAIL_REASON: Te2/5/4: Link down
Aug 26 08:28:10: %VSL-5-VSL_CNTRL_LINK: New VSL Control Link 2/5/5
Aug 26 08:28:10: %VSLP-3-VSLP_LMP_FAIL_REASON: Te2/5/5: Link down
Aug 26 08:28:10: %VSLP-2-VSL_DOWN: Last VSL interface Te2/5/5 went down
Aug 26 08:28:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel251, changed state to down
Aug 26 08:28:10: %VSLP-2-VSL_DOWN: All VSL links went down while switch is in ACTIVE role
Aug 26 08:28:10: %LINK-3-UPDOWN: Interface Port-channel251, changed state to down
Aug 26 08:28:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel250, changed state to down
Aug 26 08:28:10: %LINK-3-UPDOWN: Interface Port-channel250, changed state to down
Aug 26 08:28:10: %PFREDUN-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
Aug 26 08:28:10: %OIR-6-INSREM: Switch 1 Physical Slot 5 - Module Type LINE_CARD removed
Aug 26 08:28:10: %OIR-6-INSREM: Switch 1 Physical Slot 1 - Module Type LINE_CARD removed
Aug 26 08:28:10: %OIR-6-INSREM: Switch 1 Physical Slot 2 - Module Type LINE_CARD removed
Aug 26 08:28:10: %OIR-6-INSREM: Switch 1 Physical Slot 9 - Module Type LINE_CARD removed
Aug 26 08:29:01: %c6k_VSD_ROIR-6-TIMER_EVENT_RECV: ROIR::Receiver::Timer Process got TIMER event
Aug 26 08:29:01: %c6k_VSD_ROIR-6-TIMER_EXPIRED: ROIR::Receiver::For Switch:2 Type 2 Phy Slot 9 - SWITCHOVER TIMER timer expired
Aug 26 08:29:01: %OIR-3-VSS_PWRCYCLE: Card in Switch 2 module 9, is being power-cycled 'off (Switchover Failed)'
Aug 26 08:29:01: %C6KPWR-4-DISABLED: power to module in slot 9 set off (Switchover Failed)
Aug 26 08:29:16: %OIR-6-INSREM: Switch 2 Physical Slot 9 - Module Type LINE_CARD inserted
Aug 26 08:30:10: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as ACTIVE by VSLP
Aug 26 08:30:10: %VSL-5-VSL_CNTRL_LINK: New VSL Control Link 2/5/4
Aug 26 08:30:12: %VSLP-5-VSL_UP: Ready for control traffic
Aug 26 08:30:20: %PFREDUN-6-ACTIVE: Standby initializing for SSO mode
*Mar 1 00:00:12.351: ppc_lc_ibc_subsys_init: ETSEC IBC INIT DONE
Firmware compiled 02-Nov-12 11:44 by integ Build [101]
Aug 26 06:30:02.155: DFC9: Switch mode info received by DFC..!
Firmware Download OK:
Aug 26 06:30:23.979: %SYS-DFC9-5-RESTART: System restarted --
Cisco IOS Software, c4lc Software (c4lc-SP-M), Version 15.0(1)SY3, RELEASE SOFTWARE (fc2)
Compiled Mon 19-Nov-12 18:57 by prod_rel_team
Aug 26 06:30:24.067: DFC9: Currently running ROMMON from S (Gold) region
Aug 26 08:31:10: %DIAG-6-RUN_MINIMUM: Switch 2 Module 9: Running Minimal Diagnostics...
Aug 26 08:31:13: %QOS-3-HA_BULK_SYNC_BEFORE_TIMEOUT: QOS-HA-BLK-SYNC-PROCESS: Failure in completing bulk sync before timeout
Aug 26 08:31:16: %OIR-6-INSREM: Switch 1 Physical Slot 5 - Module Type LINE_CARD inserted
Aug 26 08:31:24: %DIAG-6-RUN_MINIMUM: Switch 1 Module 5: Running Minimal Diagnostics...
Aug 26 08:31:38: %DIAG-6-DIAG_OK: Switch 1 Module 5: Passed Online Diagnostics
Aug 26 08:31:39: %OIR-6-SP_INSCARD: Card inserted in Switch_number = 1, physical slot 5, interfaces are now online
Aug 26 08:31:40: %DIAG-6-DIAG_OK: Switch 2 Module 9: Passed Online Diagnostics
Aug 26 08:31:40: %C6KENV-4-LOWER_SLOT_EMPTY: The lower adjacent slot of module 9 might be empty. Airdam must be installed in that slot to be NEBS compliant
Aug 26 08:31:40: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/5, changed state to down
Aug 26 08:31:40: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/6, changed state to down
Aug 26 08:31:41: %VSLP-5-VSL_UP: Ready for data traffic
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface Port-channel251, changed state to up
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface Port-channel250, changed state to up
Aug 26 08:31:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel251, changed state to up
Aug 26 08:31:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel250, changed state to up
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/9, changed state to down
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/10, changed state to down
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/13, changed state to down
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/14, changed state to down
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/17, changed state to down
Aug 26 08:31:41: %OIR-6-SP_INSCARD: Card inserted in Switch_number = 2, physical slot 9, interfaces are now online
Aug 26 08:31:41: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/18, changed state to down
Aug 26 08:31:42: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/5, changed state to up
Aug 26 08:31:42: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/6, changed state to up
Aug 26 08:31:43: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/9, changed state to up
Aug 26 08:31:43: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/10, changed state to up
Aug 26 08:31:43: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/13, changed state to up
Aug 26 08:31:43: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/14, changed state to up
Aug 26 08:31:43: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/17, changed state to up
Aug 26 08:31:43: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/18, changed state to up
Aug 26 08:31:48: %LINK-3-UPDOWN: Interface Port-channel210, changed state to up
Aug 26 08:31:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/6, changed state to up
Aug 26 08:31:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/14, changed state to up
Aug 26 08:31:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel210, changed state to up
Aug 26 08:31:49: %LINK-3-UPDOWN: Interface Port-channel220, changed state to up
Aug 26 08:31:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/5, changed state to up
Aug 26 08:31:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/13, changed state to up
Aug 26 08:31:49: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/10, changed state to down
Aug 26 08:31:49: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/18, changed state to down
Aug 26 08:31:49: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/9, changed state to down
Aug 26 08:31:49: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/17, changed state to down
Aug 26 08:31:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel220, changed state to up
Aug 26 08:31:50: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/18, changed state to up
Aug 26 08:31:50: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/9, changed state to up
Aug 26 08:31:50: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/10, changed state to up
Aug 26 08:31:50: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/9/17, changed state to up
Aug 26 08:31:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/10, changed state to up
Aug 26 08:31:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/18, changed state to up
Aug 26 08:31:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/9, changed state to up
Aug 26 08:31:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/9/17, changed state to up
*Aug 26 06:20:21.975: SW1_STBY: SP: Currently running ROMMON from S (Gold) region
Aug 26 06:31:10.101: %OIR-SW1_STBY-6-INSPS: Power supply inserted in slot 1
Aug 26 06:31:10.105: %C6KPWR-SW1_STBY-4-PSOK: power supply 1 turned on.
Aug 26 06:31:10.105: %OIR-SW1_STBY-6-INSPS: Power supply inserted in slot 2
Aug 26 06:31:10.105: %C6KPWR-SW1_STBY-4-PSOK: power supply 2 turned on.
Aug 26 06:31:12.141: %C6KENV-SW1_STBY-4-FANHPMODE: Switch 1 Fan-tray 1 is operating in high power mode
Aug 26 06:31:12.165: %FABRIC-SW1_STBY-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
Aug 26 06:31:24.049: %DIAG-SW1_STBY-6-RUN_MINIMUM: Switch 1 Module 5: Running Minimal Diagnostics...
Aug 26 06:31:24.049: %CONST_DIAG-SW1_STBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestLoopback due to: the port is used as a VSL link.
Aug 26 06:31:24.049: %CONST_DIAG-SW1_STBY-6-DIAG_PORT_SKIPPED: Module 5 port 5 is skipped in TestLoopback due to: the port is used as a VSL link.
Aug 26 06:31:34.433: %CONST_DIAG-SW1_STBY-6-DIAG_PORT_SKIPPED: Module 5 port 4 is skipped in TestChannel due to: the port is used as a VSL link.
Aug 26 06:31:38.941: %DIAG-SW1_STBY-6-DIAG_OK: Switch 1 Module 5: Passed Online Diagnostics
Aug 26 06:31:54.717: %SSH-SW1_STBY-5-DISABLED: SSH 1.99 has been disabled
Aug 26 08:31:54: %SYS-SW1_STBY-6-CLOCKUPDATE: System clock has been updated from 08:31:54 MESZ Mon Aug 26 2013 to 08:31:54 MESZ Mon Aug 26 2013, configured from console by console.
Aug 26 08:31:57: %SSH-SW1_STBY-5-DISABLED: SSH 2.0 has been disabled
Aug 26 08:32:06: %SYS-SW1_STBY-5-RESTART: System restarted --
Aug 26 08:32:06: %SSH-SW1_STBY-5-ENABLED: SSH 2.0 has been enabled
Aug 26 08:32:07: %SYS-SW1_STBY-3-LOGGER_FLUSHED: System was paused for 00:01:33 to ensure console debugging output.
Aug 26 08:32:08: %C6KENV-SW1_STBY-4-ADJACENT_SLOTS_EMPTY: Two adjacent slots of module 5 might be empty. Airdams must be installed in these slots to be NEBS compliant
Aug 26 08:32:19: %VS_GENERIC-6-VS_HA_HOT_STANDBY_NOTIFY: Standby switch is in Hot Standby mode
Aug 26 08:32:19: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Aug 26 08:32:19: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Aug 26 08:32:19: %SSH-SW1_STBY-5-DISABLED: SSH 2.0 has been disabled
Aug 26 08:32:19: %SSH-SW1_STBY-5-ENABLED: SSH 2.0 has been enabled
Aug 26 08:32:19: %PFREDUN-SW1_STBY-6-STANDBY: Ready for SSO mode
Aug 26 08:32:27: %OIR-6-INSREM: Switch 1 Physical Slot 1 - Module Type LINE_CARD inserted
Aug 26 08:32:28: %OIR-6-INSREM: Switch 1 Physical Slot 2 - Module Type LINE_CARD inserted
Aug 26 08:32:28: %OIR-6-INSREM: Switch 1 Physical Slot 9 - Module Type LINE_CARD inserted
Thank you
I have this update from cisco:
This is not buggy behavior. I have both researched for known issues, and
checked with the dev folks, as well as have tried to reproduce the issue
extensively but have not seen this behavior. After all these attempts
this issue should be considered a one-time or transient occurrence.
--> Would it always be best to do an OIR of the corresponding modul
whenever we will get this message again or is there any other
recommendation on how to react in this situation?
While there are some known behaviors with the XDR process in older
versions of code, we cannot generalize them in each case. XDR process
can be a victim in some cases as well.
Any errors seen with XDR process will require further review from TAC on
a per case basis. Hence I would suggest getting in touch with TAC if you
see errors with the XDR process, especially if you see the
"%FIB-2-FIBDISABLE:" error.
this should be one time error , remove card and place it back it should help
