08-26-2013 11:44 PM - edited 03-16-2019 07:03 PM
Hi All,
I'm trying to install the CUCM 8.6.1 on the MCS 7845-I3 server & got the "Unsupported Hardware" during the installation wizard.
Not sure we are getting this error since I3 servers are alreday in the supported list.
Thanks ina Advance...
08-26-2013 11:51 PM
what is the full part number of the MCS box.
It may be like you are using 7845-I3-CCE2 server which are not supported for the CUCM installation.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
08-26-2013 11:54 PM
Hi Ronak,
Thanks for your reply. Exact part code is MCS-7845-I3-K9-CMC2.
08-27-2013 12:07 AM
Hi ,
The server is very much supported with Call manager 8.6.x with 6GB DRAM and 146GB HDD.
can u share the error snapshot?
regds,
aman
08-26-2013 11:55 PM
Hi ,
Can u share the exact PART Code of MCS server? Also, snapshot of error message which comes.
regds,
aman
