Cat6509E SPAN Session
Aug 27th, 2013
We had a SPAN session in our Cat6509E (VSS) where we mirrored 3 vlan.  After we changed that SPAN session and we left only one VLAN, we noticed  swith was still mirroring old vlan traffic. Is typical that behaviour?  Can we reset it?
Best regards,
Dmytro Skotnikov Tue, 08/27/2013 - 12:20
  • Cisco Employee,
Hello Antonio,
Behavior you mentioned it not typical, switch reprogramm adjacency for SPAN session as soon you change a configuration for it. The reliable way to check if it's working correctly is to remove monitor session and configure it again
# no monitor session
# monitor session
Would you be so kind to capture the following outputs:
# show version
# show module
# show monitor detail
# show monitor session all
# show monitor session ingress replication-mode
# show monitor session egress replication-mode
antonio.pezuela Wed, 08/28/2013 - 01:36
After more than one hour, the span session started to work fine. It is really a strange behaviour.
xxxxxx#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXJ2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Dec-11 19:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
xxxxxx uptime is 41 weeks, 3 days, 16 hours, 21 minutes
Uptime for this control processor is 41 weeks, 3 days, 16 hours, 28 minutes
Time since MOLWN01 switched to active is 41 weeks, 3 days, 16 hours, 26 minutes
System returned to ROM by reload at 17:00:50 CET Sat Nov 10 2012 (SP by reload)
System restarted at 17:05:43 CET Sat Nov 10 2012
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXJ2.bin"
Host configuration file is "tftp://10.1.36.250/config.txt"
Last reload reason: bus error at PC 0x42DB1ED8, address 0x0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-V-E (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX1504GKK2
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
29 Virtual Ethernet interfaces
124 Gigabit Ethernet interfaces
48 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
xxxxxx#  show module
Mod Ports Card Type                              Model              Serial No.
  1   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL1513A3TR
  2    1  Application Control Engine Module      ACE20-MOD-K9       SAL1445YUVN
  3    4  WiSM 2 WLAN Service Module             WS-SVC-WISM2-K9    SAL1531LMY9
  4    6  Firewall Module                        WS-SVC-FWM-1       SAD114001MT
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1514AF23
  6    5  Supervisor Engine 720 10GE (RPR-Warm)  VS-S720-10G        SAL1513AACC
  7    1  Application Control Engine Module      ACE30-MOD-K9       SAL1641PSCY
  9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1123QJ2D
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  e05f.b974.b2a0 to e05f.b974.b2af   1.0   12.2(18r)S1  12.2(33)SXJ2 Ok
  2  f866.f29a.8860 to f866.f29a.8867   2.6   ace2t_main_d A2(3.4)      PwrDown
  3  e05f.b994.6330 to e05f.b994.633f   1.0   12.2(18r)S1  12.2(33)SXJ2 Ok
  4  001d.45f8.d364 to 001d.45f8.d36b   4.2   7.2(1)       4.1(6)       Ok
  5  8843.e18a.10f0 to 8843.e18a.10f7   4.0   8.5(4)       12.2(33)SXJ2 Ok
  6  588d.09e6.0bcc to 588d.09e6.0bd3   4.0   8.5(4)       12.2(33)SXJ2 Ok
  7  e05f.b9ab.5df2 to e05f.b9ab.5df9   1.0   ace2t_main_d A5(2.1)      Ok
  9  001b.53b5.60c0 to 001b.53b5.60ef   2.9   12.2(14r)S5  12.2(33)SXJ2 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card WS-F6700-DFC3C     SAL1514AGT7  1.4    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1513AARC  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL150989PR  5.1    Ok
  6  Policy Feature Card 3       VS-F6K-PFC3C       SAL15129K1Z  1.1    Ok
7/0 ACE Expansion Card  1       ACEMOD-EXPN-DC     SAL1641PQHS  1.1    Ok
7/1 ACE Expansion Card  2       ACEMOD-EXPN-DC     SAL1641PQHF  1.1    Ok
  9  Centralized Forwarding Card WS-F6700-CFC       SAL1006D3DW  2.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Not Applicable
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  7  Pass
  9  Pass
xxxxxx#show monitor detail
Session 3
Type                   : Local Session
Description            : -
Source Ports           :
    RX Only            : None
    TX Only            : None
    Both               : None
Source VLANs           :
    RX Only            : None
    TX Only            : None
    Both               : 64
Source RSPAN VLAN      : None
Destination Ports      : Gi1/9/26
Filter VLANs           : None
Dest RSPAN VLAN        : None
Source IP Address      : None
Source IP VRF          : None
Source ERSPAN ID       : None
Destination IP Address : None
Destination IP VRF     : None
Destination ERSPAN ID  : None
Origin IP Address      : None
IP QOS PREC            : 0
IP TTL                 : 255
Egress SPAN Replication State:
Operational mode       : Centralized
Configured mode        : Centralized (default)
xxxxxx#show monitor session all
Session 1
Type                   : Service Module Session
Modules allowed        : 1-49
Modules active         : 20,36
BPDUs allowed          : Yes
Session 3
Source VLANs           :
    Both               : 64
xxxxxx#show monitor session egress replication-mode
Egress SPAN Replication Mode Session State:
Session          : 3
Session Type     : Local Session
Configured mode  : Centralized/Default
Session          : 1
Session Type     : Unknown
Global Egress SPAN Replication Mode Capability:
Slot          Egress Replication Capability
No       LSPAN           RSPAN             ERSPAN
17     Distributed      Distributed        Distributed
19     Distributed      Distributed        Distributed
20     Centralized      Centralized        Centralized
21     Distributed      Distributed        Distributed
22     Distributed      Distributed        Distributed
23     Distributed      Distributed        Distributed
25     Distributed      Distributed        Centralized
33     Distributed      Distributed        Distributed
35     Distributed      Distributed        Distributed
36     Centralized      Centralized        Centralized
37     Distributed      Distributed        Distributed
38     Distributed      Distributed        Distributed
39     Distributed      Distributed        Distributed
41     Distributed      Distributed        Centralized
Dmytro Skotnikov Wed, 08/28/2013 - 01:51
  • Cisco Employee,
Hello Antonio,
I can't see any session with configured source, what SPAN session are you reffering to? Did it become to work correcly by itself?
Best regards,
Dmitry Skotnikov
antonio.pezuela Wed, 08/28/2013 - 02:09
This is is the SPAN session, before it had 3 vlans and It becomes to work correctly by itself after one hour and half.
Session 3
Source VLANs           :
    Both               : 64
Related Content
