Warning message
RV110W + IPv6 Webserver Inbound access
Aug 27th, 2013
Model : RV110W      Firmware : 1.2.0.9
Hi!
I'm studying the RV110W IPv6 Firewall in the context of a long IPv6 study / Blog post ( 30+ posts yet ).
The RV110W IPv6 Firewall got me totally puzzled.
I've remade all the tests, and this appears :
To allow external access to an IPv6 Web Server located on the Lan side of the RV110W, it seems that :
creating an inbound allow rule is useless and unneeded.
creating a Single Port Forwarding rule is compulsory and sufficient.
1. Can anybody confirm this ?
2. Does this IPv6 Single Port Forwarding rule actually automatically creates an ' invisible ' IPv6 Firewall allow in rule ?
3. How comes an IPv6 Firewall allow in rule is not enough ?
4. could anybody explain me this misterious sentence, from the RV110W admin guide :
    " Port forwarding is not appropriate for servers on the LAN, since there is a dependency on the LAN device making an outgoing connection before incomming ports are opened. Some applications require ... ... "
   What is appropriate for servers on the LAN then ? Isn't LAN the place for servers ? isn't port forwarding the historical way to make Lan servers accessible to the outside world ? This sentence seems to describe Statefull Firewall functionning, so is the sentence mistyped, and actually should be ' Port Forwarding IS appropriate for servers on the LAN, since ... " ?
Thanks for any help
PS. I also found an IPv6 Firewall ICMPv6 quirk, that I put on another thread
lariasqu Fri, 08/30/2013 - 13:58
Hi computerone1, thank you for using our forum, my name is Luis I am part of the Small business Support community.
Well as you know Port forwarding and the Access List are different, the Port forwarding forward the port and the Access list create a rule to provide access or deny it. I this case I will recommend you to use both protocols in order provide control of the access to your server.
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
