Warning message
L2L IKEv1 Tunnel - Phase 1 Failure ASA 5520's IOS 8.2
Aug 27th, 2013
I have been struggling with this for the past few days and have made very little headway.  I have both sides configured and they are identical in regards to the tunnel.  It appears that phase 1 is not completing.  I will submit the configs first and then the debug crypto isakmp 127. I used beyond compare to compare the differences between them and everything looks good.  The items in question are in red.  The first mismatch in red seems strange since I have 3 policies and they are identical.  The transport is also identical.  Where is the mismatch?  The What am I doing wrong?
Internal ASA Config
access-list Convention-l2l-VPN extended permit ip 10.0.0.0 255.0.0.0 192.168.0.0 255.255.255.0
access-list Convention-l2l-VPN extended permit ip 10.0.0.0 255.0.0.0 192.168.1.0 255.255.255.0
access-list Convention-l2l-VPN extended permit ip 10.0.0.0 255.0.0.0 host 192.168.5.19
access-list Convention-l2l-VPN extended permit ip 10.0.0.0 255.0.0.0 host 192.168.5.17
access-list Convention-l2l-VPN extended permit ip 10.0.0.0 255.0.0.0 host 192.168.5.18
route Outside 0.0.0.0 0.0.0.0 5.5.5.5 1
route Corp 10.0.0.0 255.0.0.0 10.0.3.17 1
route Outside 9.9.9.9 255.255.255.255 5.5.5.5 1
route Outside 192.168.0.0 255.255.240.0 5.5.5.5 1
crypto ipsec transform-set Convention esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 4608000
crypto map VENDORVPNMAP 251 match address Convention-l2l-VPN
crypto map VENDORVPNMAP 251 set peer 9.9.9.9
crypto map VENDORVPNMAP 251 set transform-set Convention
crypto map VENDORVPNMAP 251 set security-association lifetime seconds 3600
crypto map VENDORVPNMAP 251 set security-association lifetime kilobytes 4608000
crypto map VENDORVPNMAP interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
encryption 3des
hash sha
group 1
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group 9.9.9.9 type ipsec-l2l
tunnel-group 9.9.9.9 ipsec-attributes
pre-shared-key *
Remote Site ASA
access-list Convention-l2l-VPN extended permit ip 192.168.0.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list Convention-l2l-VPN extended permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list Convention-l2l-VPN extended permit ip host 192.168.5.19 10.0.0.0 255.0.0.0
access-list Convention-l2l-VPN extended permit ip host 192.168.5.17 10.0.0.0 255.0.0.0
access-list Convention-l2l-VPN extended permit ip host 192.168.5.18 10.0.0.0 255.0.0.0
route XPOS-INET 0.0.0.0 0.0.0.0 9.9.9.9 1
route XPOS-INET 10.0.0.0 255.0.0.0 9.9.9.9 1
route XPOS-INET 5.5.5.5 255.255.255.255 9.9.9.9 1
route CORP-EVENT 192.168.0.0 255.255.0.0 192.168.0.33 1
crypto map VENDORVPNMAP 251 set peer 5.5.5.5
crypto map VENDORVPNMAP interface XPOS-INET
crypto isakmp enable XPOS-INET
encryption aes-256
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 1
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group 5.5.5.5 type ipsec-l2l
tunnel-group 5.5.5.5 ipsec-attributes
pre-shared-key *****
Debug Crypto Isakmp 127 (from Remote ASA)
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, processing SA payload
Jan 01 20:38:51 [IKEv1]: Phase 1 failure:  Mismatched attribute types for class Group Description:  Rcv'd: Group 1  Cfg'd: Group 2
Jan 01 20:38:51 [IKEv1]: Phase 1 failure:  Mismatched attribute types for class Group Description:  Rcv'd: Group 2  Cfg'd: Group 1
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, Oakley proposal is acceptable
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, processing VID payload
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, Received NAT-Traversal ver 02 VID
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, Received NAT-Traversal ver 03 VID
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, Received NAT-Traversal RFC VID
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, Received Fragmentation VID
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, processing IKE SA payload
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, IKE SA Proposal # 1, Transform # 1 acceptable  Matches global IKE entry # 4
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, constructing ISAKMP SA payload
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, constructing NAT-Traversal VID ver 02 payload
Jan 01 20:38:51 [IKEv1 DEBUG]: IP = 5.5.5.5, constructing Fragmentation VID + extended capabilities payload
Jan 01 20:38:51 [IKEv1]: IP = 5.5.5.5, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 132
Jan 01 20:38:53 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Jan 01 20:38:53 [IKEv1]: IP = 5.5.5.5, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jan 01 20:38:54 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Jan 01 20:38:54 [IKEv1]: IP = 5.5.5.5, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jan 01 20:38:55 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Jan 01 20:38:55 [IKEv1]: IP = 5.5.5.5, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jan 01 20:38:57 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Jan 01 20:38:57 [IKEv1]: IP = 5.5.5.5, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jan 01 20:38:59 [IKEv1]: IP = 5.5.5.5, Duplicate Phase 1 packet detected.  Retransmitting last packet.
Jan 01 20:38:59 [IKEv1]: IP = 5.5.5.5, P1 Retransmit msg dispatched to MM FSM
Jan 01 20:38:59 [IKEv1]: IP = 5.5.5.5, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 132
Jan 01 20:39:01 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Jan 01 20:39:01 [IKEv1]: IP = 5.5.5.5, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jan 01 20:39:07 [IKEv1]: IP = 5.5.5.5, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 132
Jan 01 20:39:07 [IKEv1]: IP = 5.5.5.5, Duplicate Phase 1 packet detected.  Retransmitting last packet.
Jan 01 20:39:07 [IKEv1]: IP = 5.5.5.5, P1 Retransmit msg dispatched to MM FSM
Jan 01 20:39:15 [IKEv1]: IP = 5.5.5.5, Duplicate Phase 1 packet detected.  Retransmitting last packet.
Jan 01 20:39:15 [IKEv1]: IP = 5.5.5.5, P1 Retransmit msg dispatched to MM FSM
Jan 01 20:39:15 [IKEv1 DEBUG]: IP = 5.5.5.5, IKE MM Responder FSM error history (struct &0xac4ff070)  <state>, <event>:  MM_DONE, EV_ERROR-->MM_WAIT_MSG3, EV_RESEND_MSG-->MM_WAIT_MSG3, NullEvent-->MM_SND_MSG2, EV_SND_MSG-->MM_SND_MSG2, EV_START_TMR-->MM_SND_MSG2, EV_RESEND_MSG-->MM_WAIT_MSG3, EV_RESEND_MSG-->MM_WAIT_MSG3, NullEvent
Jan 01 20:39:15 [IKEv1 DEBUG]: IP = 5.5.5.5, IKE SA MM:2d039532 terminating:  flags 0x01000002, refcnt 0, tuncnt 0
Jan 01 20:39:15 [IKEv1 DEBUG]: IP = 5.5.5.5, sending delete/delete with reason message
nathan demers Tue, 08/27/2013 - 16:31
Additional note:
This line is inaccurate:
Correct line for both FWs
     crypto ipsec transform-set Convention esp-aes-256 esp-sha-hmac
nathan demers Wed, 08/28/2013 - 12:06
For everyone elses information the tunnel information is correct but the routes were incorrect.
my default gateway was bad.
I was using the outside interface and I needed to send it to the default gateway of the OUTSIDE interface not the interface itself.  So in theory it would be
route XPOS-INET 0.0.0.0 0.0.0.0 9.9.9.1 1
route XPOS-INET 10.0.0.0 255.0.0.0 9.9.9.1 1
route XPOS-INET 5.5.5.5 255.255.255.255 9.9.9.1 1
Hope this helps others.
Related Content
