Warning message
mcast & NAT on an 891 ISR
Trying to set up an 891 to serve as a gatway for a LAN and a v2 pim router for some multicast sources. The result is from a marriage of two (possibly incompatible) trips through the forums. The last piece of the puzzle is this:
  • If I set the the isp-facing interface to "nat outside," I can get online, but the router no longer shows as a pim neighbor at the ISP.
  • If I disable nat-outside, it shows back up in the neighbor list, but devices can't get online.
I've found references to "multicast-routing distributed" online, but the router doesn't seem to support it (invalid input).
Querying the far router is a neat service from my ISP (but naturally only handles show commands).
Is there a way to enable distributed mcast routing? Some preliminary step I've missed? System version is 12.4(22r)YB3.
