08-28-2013 06:06 AM - edited 07-04-2021 12:43 AM
Dear Community Members,
I have a need to setup three (3) VLANs with different SSID's for students , staff and visitors in a College.
The controller is Cisco 5508 with Cisco 3502E-E-K9 AP
presently the wireless network is flat with just one VLAN
NB.
Staff would log in using active directory user name and password.
Student would log in using username and Registration number Possibly using RADIUS SERVER
How best can i achieve this.
08-28-2013 06:36 AM
If you have a flat network you can't segregate the traffic. You can create the SSID's you have listed, but they will be mapped to the vlan everything is on. If you are using AD and want to authenticate with that, then I suggest you also have a radius server and you need to also use 802.1x. Devices that connect need to support 802.1x. I don't know what devices you have nor what it can or can't support, but in an ideal environment, all your staff laptops are joined to the domain so you can push out the wireless GPO. Students and Guest, well that depends on what you want to do with them. Students are also in AD, but you will need to supply instructions on how they would setup their devices to connect. if you plan on using 802.1x.
Might be best to talk to your local SE to help plan what you need to do. Typically we would sit with a customer for a couple hours or a day to gather information to determine the best setup.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
08-30-2013 02:24 PM
Scenes you are using single vlan so the point of have multiple SSID is useless and the better approach will be using the AD for both authentication and managing the Group policy for both. In this way you can manage both students and Staff Kindly see the following link for step by step config and understand Group policy
Server 2008/2012
cisco document server 2003 (another explaining in detail the flow)
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
