Custom Greeting Using Phone for Recording (CUCX 9.1.1)
Matt Crosby
I'm running Unity Connection 9.1.1 and I am attempting to record a custom greeting for one of my users. I accidently punched in the wrong number in the Media Master Control Panel when it prompted me for a number.
I now cannot remove the stupid number to put a new one in.
I have tried removing the user and then importing the user back into the system. The Media Master Control Panel still has the wrong number stored.
How do I change the number so that I can use one of my IP phones to record the greeting?
-Matt
5 Replies 5
Chris Deren
On the media master click Options --> Playback & recording settings.
Chris
Doesn't do anything. I tried that.
I am running Windows 8 with firefox. I thought this to be an issue with firefox, so I tried IE and Chrome. Both of those also did nothing once I selected (Options>Playback and Recording... ).
I also tried clearing my cache in my java console as well as my browser. Didn't help.
I tried changing my options, saving, and then going back in and selecting the phone as the recording device/playback device. It never prompts me for a number. It keeps attempting to contact the incorrect number.
-Matt
Matt Crosby
To correct this problem, I had to uninstall Java completely from my device.
Once reloaded, I could point to a new phone number.
-Matt
Matt Crosby
Java applet in Mozilla was keeping me from being able to change the extension of the phone I wish to record from.
I opened it up in Google Chrome and Internet Explorer, worked just fine.
-Matt
slashdots
Nice to hear you found a solution by yourself.
However I'd like to mention, that your running into a Bug:
https://tools.cisco.com/bugsearch/bug/CSCue74920
If you experience this bug and are running Java Runtime Environment 7 on your computer, just install JRE 6 and the Pop-up will show as expected.
As a permanent solution you can upgrade your Unity Connection according to the details in the bugs description
cheers
slashdots
