J4W 9.2.X won't receive profile pictures
Aug 29th, 2013
Hi all
For some reason I can't get J4W 9.2.X to recieve profile pictures from our webserver. However it works fine in version 9.1.X.
Here is a copy of our xml config:
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
<Client>
</Client>
<Directory>
  <DirectoryServerType>EDI</DirectoryServerType>
  <DisableSecondaryNumberLookups>0</DisableSecondaryNumberLookups>
  <MinimumCharacterQuery>2</MinimumCharacterQuery>
  <SearchBase1>OU=XXXXX,DC=XXXXX,dc=XXXXXXXXX,DC=com</SearchBase1>
  <HomePhone>otherHomePhone</HomePhone>
  <OtherPhone>otherHomePhone</OtherPhone>
  <PhotoUriSubstitutionEnabled>true</PhotoUriSubstitutionEnabled>
  <PhotoUriSubstitutionToken>sAMAccountName</PhotoUriSubstitutionToken>
  <PhotoUriWithToken>http://XXXXXX/_layouts/images/employees/j4w/sAMAccountName.jpg</PhotoUriWithToken>
  <PhoneNumberMasks>+45XXXX|+## #### ####|+45XXXX|+## #### ####</PhoneNumberMasks>
</Directory>
<Options>
  <StartCallWithVideo>false</StartCallWithVideo>
  <Start_Client_On_Start_OS>true</Start_Client_On_Start_OS>
  <DockedWindowVisible>false</DockedWindowVisible>
  <Set_Status_Away_On_Inactive>true</Set_Status_Away_On_Inactive>
  <Set_Status_Inactive_Timeout>10</Set_Status_Inactive_Timeout>
</Options>
<Policies>
  <Screen_Capture_Enabled>true</Screen_Capture_Enabled>
  <File_Transfer_Enabled>false</File_Transfer_Enabled>
  <Disallowed_File_Transfer_Types>.exe;.msi;.rar;.zip;.mp3</Disallowed_File_Transfer_Types>
  <InitialPhoneSelection>deskphone</InitialPhoneSelection>
  <EnableAccessoriesManager>true</EnableAccessoriesManager>
  <UserDefinedRemoteDestinations>true</UserDefinedRemoteDestinations>
   </Policies>
<Voicemail>
  <VoiceMailService_UseCredentialsFrom>phone</VoiceMailService_UseCredentialsFrom>
</Voicemail>
</config>
Does someone know if its a bug or by design?
Kristian
mmilic Tue, 10/08/2013 - 04:40
Hi Kristian,
Problem might be in your proxy configuration. Jabber 9.1.x is worked without proxy. Jabber 9.2.x has new feature and using proxy for downloading pictures. If you dont need proxy to go on your server for download pictures maybe Jabber go
through proxy and that is a problem. Please if you dont need proxy to going on server, you must go in proxy settings and set exception for your server and you must use full link or IP adress without using wildchar like (10.*).
If this still doesnt work properly please collect Jabber PRT and attach it to this thread and I can take a look.
Marko
