Warning message
Jabber for iPad LDAP mappings and contact pictures with CUPS 8.6
Aug 29th, 2013
Hi guys,
I have some iPhones rolled out and have used the prodcut specific configuration to do some LDAP mapping (to show ipPhone number etc) and URL for retreiving contact pictures. On the iPhone this all works.
Just getting round to testing out iPad integration and thought it would also use the product specific integration, but this doesnt work (why is it even there?) so I read that you need to to set up the LDAP settings and mappings on the CUP server settings. I have done this and iPad gets the correct directory information when setting up, and I can search the directory fine. However, any custom LDAP mappings I have done aren't working, and the contact pictures don't display.
Is there somewhere else I should be doing this to get this to work?
