NATIVE_VLAN_MISMATCH on switchports configured as access
tato386
Level 6
Level 6
I need to connect a Cisco 2900 switch with a fiber port to a second Cisco 2900 that does not have any fiber ports.  In order to not spend any money on transceivers/GBIC or any other converter type device I am using a third 3700 switch that has both types of ports as a big and expensive transceiver.  Here is what I did:
Both Cisco 2900 switches are pretty much default config with no VLANs configured.  The 3700 does have several VLANs and trunks configured and I would like to keep traffic on the 2900's segregated from the 3700's VLANs.
On the 3700 switch I took a fiber port and a copper port and made them access ports like this:
int gig3/0/44
switchport mode access
switchport access vlan 4455
int gig3/0/50
The config basically works and the two 2900's seem to be talking to each other well.  But when I do "show CDP neighbor detail" and "show logging" on the 3700 I see the native VLAN mismatch errors on those two ports. I thought that by making these two ports access the fact that they are configured for VLAN4455 would be transparent to the 2900's.  Should I worry about this error?  I would like to get rid of it.  What are my options here?
Diego
Hi Diego,
CDPv2 exchanges Native-VLAN information with a TLV:
http://www.rhyshaden.com/cdp.htm
I'm not aware of a way to disable this particular TLV but you could
- configure a logging discriminator to suppress this type of syslog message
- disable CDP on a per-interface basis
- enable CDPv1 on a per-interface globally (by disabling v2)
Feel free to ask further!
Rolf
6 Replies 6
jimmysands73_2
Level 5
Level 5
Have you wiggled the cable?
glen.grant
  It won't hurt anything it's just a informational message saying the vlan on the other end doesn't match . The only way would be to match  the vlan on the 2900 which probably doesn't even allow you to configure a vlan that high or turn off cdp between the switches .   That's a normal message but does not hurt anything.
Hi Diego,
Rolf
I think I will just have to train myself to live with it.
Thanks to all.
Rgds,
Diego
Hi Diego,
if you want to get rid of this type of syslog messages, you can configure a logging discriminator (if your IOS supports it):
logging discriminator NVM mnemonics drops NATIVE_VLAN_MISMATCH
logging buffered discriminator NVM
logging console discriminator NVM
#show logging
Console logging: level debugging, 37 messages logged, xml disabled,
filtering disabled, discriminator(NVM),
0 messages rate-limited, 71 messages dropped-by-MD
Buffer logging:  level debugging, 37 messages logged, xml disabled,
Hope that helps
Rolf
Rolf,
If I can't train myself to ignore the error your suggestion is certainly a good one!
Thanks again,
Diego
