Warning message
Mix of RIP Ver 1 and Ver 2 in network
Answered Question
Aug 29th, 2013
Hi ,
i have two routers connected back to back as below
Router  1(loopback 1.1.1.1) --------------- Router 5  (loopback 5.5.5.5)
Now router has rip ver 1 enabled and router 5 has rip ver 2 enabled
My understanding was eventhough rip ver 1 can recieve ver 2 updates still communication wont happen between Router 1 and Router 5  because rip ver 1 is not capable of sending ver 2 updates
But i am able to ping from Router 1 to Router 5 loopback i.e 5.5.5.5
Router 1
R1#sh ip route rip
     5.0.0.0/32 is subnetted, 1 subnets
R       5.5.5.5 [120/1] via 15.0.0.5, 00:00:07, Serial0/1
     25.0.0.0/24 is subnetted, 1 subnets
R       25.0.0.0 [120/1] via 15.0.0.5, 00:00:07, Serial0/1
Router 5
R5#sh ip route rip
(No routes learned)
Also when i check Router 5 routing table it is blank .... so i cant understand eventhoug Router 5's routing table is empty still how is Router 1 getting 5.5.5.5 entry
config's which i did
Router 1
router rip
network 1.0.0.0
network 12.0.0.0
network 13.0.0.0
network 15.0.0.0
no auto-summary
Router 5
router rip
version 2
network 5.0.0.0
network 15.0.0.0
network 25.0.0.0
network 192.0.0.0
no auto-summary
Even if i consider that Router 1 (enabled with ver 1) can learn 5.5.5.5 because it can learn ver 2 updates and Router 5 (enabled with ver 2) can't learn 1.1.1.1 because it cannot learn ver 1 updates , but as a basic rule since routing table of Router 5 is totally empty ....how come Router 1 is still getting 5.5.5.5
Ping response
R1#ping 5.5.5.5
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/23/36 ms
R1#
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R5#
Correct Answer by John Blakley about 3 years 11 months ago
RIP, by default, sends version 1 out of the interface and receives 1 and 2 updates. In this case, if you have version 1 on one router (sending/receiving v1 updates) and version 2 on another router (sending/receiving v2 updates), they cannot communicate because you're specifically configuring the router to send and receive only that version.
For example, if you have version 2 specified on one router, it expects to receive the updates in a version 2 format. On the other router, if you have the default specified, it sends version 1 out of the interface and receives 1 and 2 on the interface. This is why you're receiving the routes on your one router, but you're not seeing them on the other. You can change this behavior per interface with "ip rip send version " or "ip rip receive version ". So, you could receive 1 and send 2 if you needed. Without this stipulation on the interface though, the default is to send version 1 and receive both versions.
HTH,
John
*** Please rate all useful posts ***
Correct Answer by Rolf Fischer about 3 years 11 months ago
R1#ping 5.5.5.5
I'll bet this behavior changes when you use the source option:
R1#ping 5.5.5.5 source 1.1.1.1
Hope that helps
Rolf
Overall Rating: 5 (2 ratings)
Correct Answer
Rolf Fischer Fri, 08/30/2013 - 10:33
  • Blue, 1500 points or more
R1#ping 5.5.5.5
Hope that helps
Rolf
Correct Answer
John Blakley Fri, 08/30/2013 - 11:57
  • Purple, 4500 points or more
HTH,
John
