Warning message
Wism1 - AP Operational Status Downloading
Aug 30th, 2013
one of my AP (AIR-LAP1131G-E-K9) has stuck on downloading. I try to restart it few times but he always stop at operational status downloading.
Other AP (same model and 1142) are working ok.
I did also try
Perform a primary image pre-download on this  AP and Perform a interchange of both the images on this AP but also no result.
Any advice?
THX,
Ivan
Shaoqin Li Fri, 08/30/2013 - 08:12
  • Bronze, 100 points or more
better get ap console log for further analysis
blenka Mon, 09/02/2013 - 18:16
Please check the software version of the WISM-1 So that you can understand that the model is supported to it or not, because if one of your AP is working with it is means the configuration is ok and WISM is working fine .
Q. What access points are supported by the Cisco WiSM?
A. The Cisco WiSM supports Cisco Aironet access points running Lightweight Access Point Protocol (LWAPP) only. This includes any enabled Cisco Aironet Series 1000 (1010,1020, 1050), Series 1100 (1120, 1130, 1140), Series 1200 (1230, 1240, 1250), and Series 1520 (1522, 1524) access points.
Trending Topics - Security & Network
