Warning message
Silent Monitoring Error
Aug 30th, 2013
I am trying to do CTIOS based Silent Monitoring with IP hardphones-
I have done the confifs,when I try to start monitoring the agent I get error-
"Voice transmitter is not installed properly in the targeted agent"
Before this I got an error-
"The workstation of the targeted agent is not receiving any voice from IP Phone'-when i disabled the wireless i got the above error.
I am using 7961 phones and Windows 7 and my IP Phone is daisy chained.
Senthil Kumar Sankar Fri, 08/30/2013 - 21:28
  • Cisco Employee,
Hello Anusuya,
Can you check what is the Winpcap version is used in the Agent/Supervisor desktop ? If it is not Winpcap 3.1, Can you try installing Winpcap 3.1 version.
Make sure you are using the NIC Card which is supported. There is a list of NIC cards which are supported for Silent Monitoring. I dont have that document handy.
Senthil
anusuya984 Tue, 09/03/2013 - 00:26
I am using NIC  Intel 82579LM .
I have winpcap 4.1.3 installed.
anusuya984 Tue, 09/03/2013 - 00:27
BTW I am trying to do CTIOS based SM with IP Hard Phones.
anusuya984 Tue, 09/03/2013 - 02:14
Ok Senthil,
Can you confirm- what is the requirement of winpcap ?I am using ctios  agent desktop 8.5,where Silent Monitoring service automatically gets installed.I have not separately installed any other application.And I see the service running(though I have tried to re-run the silent monitor set up,but nothing helps).
Senthil Kumar Sankar Tue, 09/03/2013 - 02:39
  • Cisco Employee,
Basicall Winpcap is an application used for Capturing Packets. Voice packets sent to and received by the monitored agent’s IP hard phone will be captured from the network and sent to the supervisor desktop. For the Supervisor, these packets are played in the Soundcard.
I am not sure whether you have checked the Installtion & configuration document. Below is the Note from the document.
So I would suggest you to unisnstall winpcap 4.1 and install 3.0. Long back i have seen this issue where Winpcap 4.1 used.
Senthil
anusuya984 Tue, 09/03/2013 - 08:44
Thanks Senthil,So I should install winpcap in both agent and supervisor desktops?
Senthil Kumar Sankar Sat, 09/07/2013 - 02:15
  • Cisco Employee,
Hello anusuya,
Have you tried looking into the logs with the tracing enabled. Additonally check this as well
"The CTI OS silent monitor feature requires that you modify a WinPcap registry setting after installing (or reinstalling) WinPcap. In the Windows registry go to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NPF
Change the value of the Start setting under this key from 0x00000003 to 0x00000002. Reboot the PC"
Senthil
