Warning message
Scott Fella Mon, 09/02/2013 - 06:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You might want to reference this document as it will tell you what you need to do.
https://supportforums.cisco.com/docs/DOC-26960
http://www.cisco.com/en/US/docs/wireless/ncs/1.0/command/reference/cli_app_a.pdf
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Rob Johnson Mon, 09/02/2013 - 17:11
  • Cisco Employee,
From the NCS GUI goto Administration> Appliance
What do you see?
Also, how did you get to 500GB?  You would have had to add more space.... Hopefully you added an additional disk and didn't grow the size of the disk already installed.
With Prime Infrastructure, adding more space is as easy as bringing the application down w/ ncs stop, adding an additional virtual disk then bringing the applicaiton back online.
With NCS however, there's a disk grow script  TAC runs that ties the new virtual disk w/ the original virtual disk.
omer shtivi Tue, 09/03/2013 - 02:10
Hi Rob and Scott,
Thank you for your help.
We got to 500GB by when we installed the VM we gave it 500GB (when we provisioned the VM).
We don't have an alarm in the NCS for disk space.
Only in the ESXCI we have the alarm
Rob Johnson Tue, 09/03/2013 - 04:18
  • Cisco Employee,
It looks like a portion of the screen shot above is cropped off. That portion being the % used column....
Can you please reply back with a screen shot showing all 4 columns including
Disk Source, Available Space, Used Space, % Used?
Rob Johnson Tue, 09/03/2013 - 05:22
  • Cisco Employee,
When you say you "We installed the system with more then recomended disk spack (500 GB HD)."
When the OVA gets installed, it will define what space is required depending on what size of OVA is chosen.
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.2/quickstart/guide/cpi_qsg.html#wp72032
200GB, 300GB, 400GB or 1.2TB (small, medium, large and extra large respectively)
What size of OVA did you guys install from?
omer shtivi Tue, 09/03/2013 - 05:26
We installed the meduim size,
And as you can see we didn't pass the 50 precent.
There is no alarm inside the NCS only on the ESXCI
Rob Johnson Tue, 09/03/2013 - 05:28
  • Cisco Employee,
Yes, I see your /opt is at 45%
What version of ESX are you running?
Rob Johnson Tue, 09/03/2013 - 05:47
  • Cisco Employee,
Also, do you have multiple VMs hanging off this ESX host or is NCS the only one?
omer shtivi Thu, 09/12/2013 - 06:55
Hi Rob,
Yes there is more VMs on the ESX host.
ESX version 5.1
Trending Topics - Security & Network
