ACE 30 Module Management And Cert replication in HA
veer.pratap
I have one ACE30-MOD-K9 module in Cisco 6509 chasiss working as standalone mode. how can i achive the Management of the ACE module.
If i plan to add one more ACE module in secondary chasiss of 6509 and configure HA , would my existing SSL cert will also replicate to the standy module or i have to upload a seperate cert for standby module.
Thanks in Advance.
Rgds,
Veer Pratap
ravi281278
Hi Veer,
You need to define class map for management.
SSL certificate will not replicate to standby module. We need to upload the certificate seperatly on standby ace.
ravi281278
Hi Veer,
Jorge Bejarano
Level 4
Level 4
Veer,
Any SSL certificate, key, license, chaingroup will be replicated
You need to install them to the secondary ACE.
Indeed, if both ACEs notice they have some certs, key, etc different it might cause FT takes as problem.
Jorge
