Warning message
Prime wireless accounts
Dear Sir/Madam.
Our users access wifi using local accounts at present on our wireless controllers.  One has asked if it is possible to have a countdown or account time left when logging into our wireless, would this be possible at all?  I couldn't find a way to do this looking through the options.
Thank you in advance for any help given.
Saurav Lodh Tue, 09/03/2013 - 21:28
  • Gold, 750 points or more
You can configure session timeout for clients , from CLI command, issue config wlan           session-timeout . Default value is 1800 seconds.
aqjaved Wed, 09/04/2013 - 09:15
  • Bronze, 100 points or more
To enable  the system to forward logs to a remote system or to configure the log  level, use the logging command in configuration mode. To disable this  function, use the no form of this command.
For More  Configuration, Please visit the below link
http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.2/command/reference/cli12_appendix_011.html#wp1191630685
Related Content
Trending Topics - Security & Network
