Critical Error - CUCM 8.6 on Vsphere 5.1
Answered Question
Sep 3rd, 2013
Hi voice team, a configured the vm using cucm 8.6 ova template, then i started the machine, put a lot information like, IP Address, NTP, DNS, but when the machine begin to install appears the error attached.
Correct Answer by Jaime Valencia about 3 years 11 months ago
I think Chris means the actual HW on which ESXi is installed, not the VM specs
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 09/03/2013 - 11:41
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I've seen this happen on a system that is slower than what is expected, what hardware are you running it on?
How many times do you attempt to install it? For me it installed on 3rd time.
HTH,
Chris
Thiago Gandara Tue, 09/03/2013 - 11:51
The hardware is:
Red Hat Enterprise Linux 5 (32-bit)
4 gb memory
2 CPU´s 800 MHz
80GB hard disk
I try to install 4 times, but the same screen appears.
Thanks.
Thiago Gandara Tue, 09/03/2013 - 13:13
That´s right, i move the vm host to another physical machine (supported) and works fine.
Thanks.
Chris Deren Tue, 09/03/2013 - 13:35
  • Hall of Fame,
Yes, that is what I meant.
Chris
Related Content
