ssh not support on cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin
Desong Yang
cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin installs on cisco 4500E with SUP7-E, the license level is enterservice, but can't find and use "crypto key generat rsa " to enable ssh in CLI. Who can resolve it? thinks!!!
2 Accepted Solutions
sansarav720e
Dear Yang ,
               Could you please paste extract of following command from your device ?? . I suspect your switch is running on base license without K9 image .
show version
show bootflash
show bootvar
Santhosh Saravanan
HTH Regards Santhosh Saravanan
You have both k9 (supports crypto, including ssh) and non-k9 (no ssh support) images in bootflash. Your running version is NOT the k9 version. If it was, your "show version" output would start like this:
#show ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
...and include the paragraph about cryptographic features:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Additionally you have config-register 0x2101 = boot into bootstrap (rommon). You would normally use 0x2102 = boot into image specified in boot variable.
6 Replies 6
sansarav720e
Dear Yang ,
show version
show bootflash
show bootvar
Santhosh Saravanan
James Neilson
Try
set crypto key rsa 1024
glen.grant
  Follow this link. Do you have the AAA new model command and your passwords  and or tacacs set ?
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml#diagram
Desong Yang
Switch#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:58 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010, 2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG5
Switch uptime is 24 minutes
Uptime for this control processor is 26 minutes
System returned to ROM by reload
Running default software
Jawa Revision 7, Snowtrooper Revision 0x0.0x1C
Last reload reason: Admin reload CLI
License Information for 'WS-X45-SUP7-E'
    License Level: entservices   Type: Evaluation
    Next reboot license Level: entservices
cisco WS-C4510R+E (MPC8572) processor (revision 10) with 2097152K/20480K bytes of memory.
Processor board ID FXS1716Q0UM
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from Reload
1 Virtual Ethernet interface
276 Gigabit Ethernet interfaces
14 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Directory of bootflash:/
73762  -rw-   119576292  Jul 27 2013 20:04:41 +00:00  cat4500e-universal.SPA.03.04.00.SG.151-2.SG.bin
73763  -rw-   125216116   Sep 4 2013 00:16:48 +00:00  cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin
831541248 bytes total (586387456 bytes free)
Switch#sh redundancy
Redundant System Information :
       Available system uptime = 24 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = Stateful Switchover
     Operating Redundancy Mode = Stateful Switchover
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 23 minutes
                 Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
               BOOT = bootflash:cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin,12;
        Configuration register = 0x2101
Peer Processor Information :
              Standby Location = slot 6
        Current Software state = STANDBY HOT
       Uptime in current state = 21 minutes
#show ver
thank you very mach!!!  your solution is right.
