Warning message
Cisco ACS 5.4 failed to join primary instance.
Sep 4th, 2013
Did anyone encountered this before when trying to join the secondary instance to the primary?
The same version both the box is running.
Please help.
Jatin Katyal Wed, 09/04/2013 - 13:57
  • Cisco Employee,
Do we have more than 1 interface configured on primary ACS?
~BR
Jatin Katyal
**Do rate helpful posts**
seongyee067 Wed, 09/04/2013 - 16:08
Hi,no. Only one interface configured on the primary instance.
Jatin Katyal Wed, 09/04/2013 - 16:32
  • Cisco Employee,
Can you please provide me management level debugs:
Here are the steps:
acs/acsadmin# acs-config
Escape character is CNTL/D.
Username: xxxx ( GUI ADMIN USERNAME)
Password: xxxx ( GUI ADMIN PASSWORD)
acs/acsadmin(config-acs)# debug-log mgmt level debug
Exit
Attempt to register the secondary server again.
Show acs-logs filename ACSManagement.log
Note: Once you collect the above fine. Turn off the mgmt logs with this command
           debug-log mgmt level warn
Save complete output of the ACSManagement.log in a text file and attach to your next post when possible.
~BR
Jatin Katyal
Tarik Admani Wed, 09/04/2013 - 22:13
  • Green, 3000 points or more
Is there a firewall between the two ACS appliances? Also are you able to resolve dns in both directions, primary to secondary and secondary to primary?
Tarik Admani
*Please rate helpful posts*
adriansales Mon, 03/10/2014 - 19:02
Was this issue resolved?
I am experiencing the same problem
