Layer 2 load balancing using Service Instance
Sep 4th, 2013
    Hi All,
Please help me regarding this. I need an urgent solution to this.
Currently we have cisco 7609 router connected to the extreme switch via 4X1 gig interfaces bundled into a port channel. The port-channel is running 4 service instances. But when I do the show etherchannel <no.> detail -----> I see that each service-instance/vlan is taking one link. Hence one service instance is tagging to one the physical links inside the port channel.
But since the 4 service instances only one of them has a high throughput which I want to be load balanced across the 4 member-interfaces.
My question : Is it possible for one service-instance traffic to egress from two different member links of the port-channel?
Best Regards
Saikat Chakraborty
Related Content
