WAP321 Captive Portal Issue and timeout problems
agatica01
As the title says, I'm having trouble working WAP321 cluster mode.
The problem basically is that sometimes users to connect to the wireless network, the APs do not request authentication through captive portal and users connect directly to the Internet without any security level.
Another point is that sometimes users despite being authenticated, the AP's are prompted for credentials Captive Portal 3 or more times during the day, working and connected to the network (active members).
im using
Firmware Version:                                1.0.3.4
Hopefully you can help me.
naarjuna
Hi Alejandro,
These are few articles that you can refer when you are working with the Captive Portal on the WAP321 AP. Hope these articles can help you solve the problem.
Captive Portal Instance Configuration on WAP321 Access Point
Captive Portal Instance Association on WAP321 Access Points
Hope this helps.
Naresh Arjunan
Please rate useful posts.
