Warning message
Current Apple iPAD IOS WiFi Issues (Sept 2013)
Sep 5th, 2013
  • Bronze, 100 points or more
I have a customer that notes their Wireless is running great for laptops (Windows 7, EAP-TLS) but they note their iPads get disconnected often.  Isn't this a known Apple iPad isues?  Anyone familar if Apples has fixed any wireless issues in recent iPad versions? Details?  What version Apple IOS should their iPads be using?
I believe they are on a FlexConnect/HREAP in a Remote Office with about 60 users, I'm waiting on more details.
Rasika Nayanajith Thu, 09/05/2013 - 12:39
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
What version of software running on WLC ? Are they having frequent disconnection while they are moving with iPads ? If yes this may be related to roaming & you have to look at how that is configured.
If they compare performance while iPad & Laptop kept in a fixed placed & still noticed iPad is having frequent disconnections then it may be a differnt issue.
Need to have more information to narrow down the issue.
Rasika
Jason Aarons Sat, 09/07/2013 - 06:33
There is no WCS/NCS/Prime, just the two WLCs. They are on version 7.3.101.0.
These APs are at a spoke site with 60 users running in HREAP/FlexConnect mode, registered to hub site WLCs.
Scott Fella Sat, 09/07/2013 - 07:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
I guess one of the things you also have to note is that Apple devices are sticky. They don't roam good at all:)
Take a look at the roaming section on this doc.
http://www.cisco.com/en/US/docs/wireless/technology/vowlan/bestpractices...
Also, its a good test to also test with an open authentication, wpa2-AES psk and PEAP, just to see if the issue also hits any of the other authentication methods.
Saurav Lodh Thu, 09/05/2013 - 22:18
  • Gold, 750 points or more
If you hit apple forum you will find issues related to WPA2 EAP-TLS there!
