Warning message
PRI to CCM
Sep 5th, 2013
Have a setup with a fractional T1 (Voice PRI) dialing into and out of a 2811 running CME.
Should we want to upgrade to CCM can i point the PRI on the 2811 to the CCM?  Or will i need a different kind of gateway?
John
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 09/05/2013 - 21:53
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, you can use it for CUCM, but since its fractional, then you need to use H323
Chris Deren Fri, 09/06/2013 - 06:25
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
SIP will work as well. In fact with either protocol you can share the PRI between CME and CUCM.
HTH,
Chris
