Warning message
Removing Backup Repository FTP profiles
Sep 6th, 2013
Does anybody out there know how to remove from the NCS Backup screen a FTP repository that doesn't work?
I am trying to replace it with correct settings but am unable to.
Overall Rating: 5 (1 ratings)
hyochum Fri, 09/06/2013 - 10:03
Answering my own post Hopefully this can help someone.
There is no option to remove repositories in the GUI
You must go to the CLI an type in the following:
admin#sh run | begin repository (this will list out the repositorys in your config)
admin#no repository <repository name> (this will remove the repository and any settings associated with it)
admin# sh run |begin repository (this will list out the repositorys that remain after the repository was removed)
admin#exit
admin# copy run start
JASON SIMMONS Wed, 01/29/2014 - 12:40
I've wondered how to do this for about as long as we've been runing NCS/CPI.
Only issue I had with is is that the no repository commands need to be run in config mode. (at least in CPI 1.3)
Thanks!!!
Related Content
