Warning message
Problem in SG300 POE 28 port
Sep 7th, 2013
Dear
i have problem in Poe port i have Access point TP link tl-wa5110g High Power when i bluged in switch i can`t take power from switch
note Acess point support Poe in put power 12V 1 A
thanks..
kareemmahmoud7 Sat, 09/07/2013 - 05:15
Dear Mr Tom
Thanks For reply but this device work poe
HARDWARE FEATURES
InterfaceOne 10/100M Ethernet Port(RJ45)
Support Passive PoE
and with this device with packge Converter and i try to connect this device by converter work fine but when i put in my switch don`t work
thanks..
Tom Watts Sat, 09/07/2013 - 06:43
  • Green, 3000 points or more
Hi Kareem, the passive poe is not considered a standard under 802.3af since it does not have an active component. Passive POE tries to use unused wires for power.
I can only recommend you use some sort of injector to standardize your POE to be 802.3af compliant.
-Tom
Please mark answered for helpful posts
kareemmahmoud7 Sat, 09/07/2013 - 06:48
Dear Mr Tom
Thanks Soo Much for you support which moudel supported for my switch did you frefer
Thnaks..
Tom Watts Sat, 09/07/2013 - 08:05
Hi Kareem any 802.3af injector should be compatible to the switch. I'd recommend to call the AP vendor and ask them what 802.3af injector is compatible to their product.
-Tom
