Warning message
Site-to-Site up but no ping for the local networks from both sides
Sep 9th, 2013
I have set the tunnel up between ASA 5505 and ASA 5510, but I can't ping the local networks of both ASAs.
ASA 5505
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 10.2.3.0 baghdad
name 195.112.215.16 CyberiaNetwork
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.3.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 81.90.22.188 255.255.255.248
interface Vlan3
no forward interface Vlan1
nameif voice
security-level 100
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 83.138.175.26
name-server 50.56.16.2
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service DM_INLINE_SERVICE_1
service-object ip
service-object tcp
service-object icmp echo-reply
service-object tcp eq h323
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 10.1.3.0 255.255.255.0
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 10.1.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list outside_access_in extended permit icmp any any echo-reply
access-list voice_access_in extended permit ip any any
access-list voice_access_in extended permit ip 10.1.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list voice_nat0_outbound extended permit ip any any
access-list voice_access_in_1 extended permit ip 10.1.3.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu voice 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any voice
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 dns
nat (voice) 0 access-list voice_nat0_outbound
access-group outside_access_in in interface outside
access-group voice_access_in_1 in interface voice control-plane
access-group voice_access_in in interface voice
route outside 0.0.0.0 0.0.0.0 81.90.22.185 1
route outside 10.1.3.0 255.255.255.0 81.90.22.185 1
route outside CyberiaNetwork 255.255.255.240 81.90.22.185 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.3.0 255.255.255.0 inside
http CyberiaNetwork 255.255.255.240 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 20 match address outside_1_cryptomap
crypto map outside_map 20 set pfs
crypto map outside_map 20 set peer 195.112.215.19
crypto map outside_map 20 set transform-set ESP-DES-SHA
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access voice
dhcpd auto_config outside
dhcpd address 192.168.3.5-192.168.3.36 inside
dhcpd auto_config outside vpnclient-wins-override interface inside
dhcpd enable inside
dhcprelay timeout 60
vpnclient server 109.224.18.242
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup MGvilla password *****
vpnclient username rami password *****
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy GroupPolicy2 internal
group-policy GroupPolicy2 attributes
vpn-tunnel-protocol IPSec
tunnel-group 195.112.215.19 type ipsec-l2l
tunnel-group 195.112.215.19 ipsec-attributes
pre-shared-key *****
isakmp keepalive disable
prompt hostname context
call-home reporting anonymous
Cryptochecksum:fde05056fe6d738c0b99552721973ac6
: end
ASA 5510
Result of the command: "sh run"
: Saved
ASA Version 8.2(1)
hostname ciscoasa
domain-name Luna
names
name 195.112.215.17 Cyberiaip
name 82.146.160.65 RouterCyberia
name 10.1.15.6 test
name 10.1.5.20 server
name 10.2.3.0 VILLA
dns-guard
nameif Cyberia
security-level 0
ip address 195.112.215.19 255.255.255.240
nameif ServerVpn
security-level 100
ip address 10.1.5.234 255.255.255.0
nameif VPN
security-level 100
ip address 10.1.3.198 255.255.255.0
nameif Inside2
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
ip address 192.168.2.1 255.255.255.0
management-only
ftp mode passive
clock timezone EEST 2
clock summer-time EEDT recurring last Sun Mar 0:00 last Sun Oct 0:00
dns domain-lookup Cyberia
dns domain-lookup ServerVpn
dns domain-lookup Inside2
dns server-group Backup
name-server 8.8.8.8
name-server 4.2.2.2
domain-name Luna
service-object ip
object-group service DM_INLINE_SERVICE_2
service-object tcp
service-object icmp
service-object ip
object-group service DM_INLINE_SERVICE_3
service-object ip
service-object tcp
object-group service DM_INLINE_SERVICE_4
service-object ip
service-object tcp
object-group service DM_INLINE_SERVICE_5
service-object ip
service-object icmp
service-object tcp
access-list MGVoice_splitTunnelAcl standard permit 10.1.3.0 255.255.255.0
access-list Cyberia_access_in extended permit object-group DM_INLINE_SERVICE_3 VILLA 255.255.255.0 10.1.3.0 255.255.255.0
access-list Cyberia_access_in extended permit object-group DM_INLINE_SERVICE_4 192.168.1.0 255.255.255.0 10.1.3.0 255.255.255.0
access-list server_splitTunnelAcl standard permit 10.1.5.0 255.255.255.0
access-list Guardia_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list Accounting_access_in extended permit icmp any any echo-reply
access-list Voice_nat0_outbound extended permit ip 10.1.3.0 255.255.255.0 10.1.3.192 255.255.255.192
access-list Voice_nat0_outbound extended permit ip 10.1.3.0 255.255.255.0 any
access-list Cyberia_1_cryptomap extended permit ip 10.1.3.0 255.255.255.0 VILLA 255.255.255.0
access-list VPN_nat0_outbound extended permit object-group DM_INLINE_SERVICE_5 any any
access-list VPN_nat0_outbound extended permit ip 10.1.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list VPN_nat0_outbound extended permit ip 10.1.3.0 255.255.255.0 VILLA 255.255.255.0
access-list VPN_nat0_outbound extended permit ip 10.1.3.0 255.255.255.0 10.1.3.192 255.255.255.192
access-list VPN_nat0_outbound extended permit ip 10.1.3.0 255.255.255.0 10.1.3.224 255.255.255.224
access-list Voice_splitTunnelAcl_5 standard permit 10.1.3.0 255.255.255.0
access-list MGserver_splitTunnelAcl standard permit 10.1.5.0 255.255.255.0
access-list ServerVpn_nat0_outbound extended permit ip 10.1.5.0 255.255.255.0 10.1.5.192 255.255.255.192
access-list ServerVpn_nat0_outbound extended permit ip any any
access-list ServerVpn_nat0_outbound extended permit ip 10.1.5.0 255.255.255.0 10.1.5.240 255.255.255.240
access-list test_splitTunnelAcl standard permit 10.1.5.0 255.255.255.0
access-list mgvoice_splitTunnelAcl standard permit 10.1.3.0 255.255.255.0
access-list VPN_access_in extended permit object-group DM_INLINE_SERVICE_2 any any
access-list VPN_nat0_outbound_1 extended permit ip 10.1.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list VPN_nat0_outbound_1 extended permit ip 10.1.3.0 255.255.255.0 VILLA 255.255.255.0
access-list Cyberia_cryptomap_20 extended permit ip 10.1.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list Cyberia_access_in_1 extended permit ip 192.168.1.0 255.255.255.0 any
access-list Cyberia_access_in_1 extended permit ip VILLA 255.255.255.0 any
pager lines 24
logging enable
logging from-address [email protected]
logging rate-limit 50 15 level 4
mtu Cyberia 1500
mtu ServerVpn 1500
mtu VPN 1500
mtu Inside2 1500
mtu management 1500
ip local pool Vocie 10.1.3.235-10.1.3.245 mask 255.255.255.0
ip local pool test 10.1.5.241-10.1.5.254 mask 255.255.255.0
no failover
icmp permit any Cyberia
icmp permit any VPN
asdm history enable
arp timeout 14400
global (Cyberia) 1 interface
nat (VPN) 0 access-list VPN_nat0_outbound_1
access-group Cyberia_access_in_1 in interface Cyberia control-plane
access-group Cyberia_access_in in interface Cyberia
access-group VPN_access_in in interface VPN
router rip
route Cyberia 0.0.0.0 0.0.0.0 Cyberiaip 1
route VPN 0.0.0.0 0.0.0.0 10.1.3.2 2
route Cyberia 81.90.22.184 255.255.255.248 Cyberiaip 1
route Cyberia 192.168.1.0 255.255.255.0 Cyberiaip 1
http server enable
http 192.168.2.0 255.255.255.0 management
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ASA-IPSEC esp-des esp-sha-hmac
crypto ipsec transform-set VILLA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set OFFICE esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Cyberia_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Cyberia_map1 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Lunasat_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map MAP-OUTSIDE 1 match address Cyberia_1_cryptomap
crypto map MAP-OUTSIDE 1 set pfs
crypto map MAP-OUTSIDE 1 set peer 109.224.18.242
crypto map MAP-OUTSIDE 1 set transform-set VILLA
crypto map MAP-OUTSIDE 1 set security-association lifetime seconds 3600
crypto map MAP-OUTSIDE 20 match address Cyberia_cryptomap_20
crypto map MAP-OUTSIDE 20 set pfs
crypto map MAP-OUTSIDE 20 set peer 81.90.22.188
crypto map MAP-OUTSIDE 20 set transform-set VILLA
crypto map MAP-OUTSIDE 20 set security-association lifetime seconds 3600
crypto map MAP-OUTSIDE 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map MAP-OUTSIDE interface Cyberia
crypto ca server
shutdown
smtp from-address [email protected]
crypto isakmp enable Cyberia
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 28800
telnet timeout 5
ssh timeout 5
console timeout 0
management-access VPN
vpn load-balancing
interface lbpublic Cyberia
interface lbprivate ServerVpn
threat-detection statistics port
threat-detection statistics protocol
webvpn
enable Cyberia
enable VPN
enable Inside2
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
group-policy server internal
group-policy server attributes
dns-server value 4.2.2.2 8.8.8.8
split-tunnel-policy tunnelspecified
split-tunnel-network-list value server_splitTunnelAcl
group-policy Voice internal
group-policy Voice attributes
split-tunnel-network-list value Voice_splitTunnelAcl_5
nem enable
client-firewall none
group-policy MGserver internal
group-policy MGserver attributes
dns-server value 4.2.2.2 8.2.2.2
split-tunnel-network-list value MGserver_splitTunnelAcl
group-policy MGVoice internal
group-policy MGVoice attributes
split-tunnel-network-list value MGVoice_splitTunnelAcl
group-policy mgvoice internal
group-policy mgvoice attributes
split-tunnel-network-list value mgvoice_splitTunnelAcl
username test password k83iXWPan0Gg1s04 encrypted privilege 0
username test attributes
vpn-group-policy Voice
username guardiairaq password espwxXvOvtn.9lWp encrypted privilege 0
username guardiairaq attributes
vpn-group-policy server
username George password Z/rrvuow9WD495rt encrypted privilege 0
username George attributes
username Mohammad password WeG4Vh8yUivCpxGJ encrypted privilege 0
username Mohammad attributes
username MohammadD password WeG4Vh8yUivCpxGJ encrypted privilege 0
username MohammadD attributes
username Rami password Ap6uwufXoaDJPqK5 encrypted privilege 0
username Rami attributes
username Ziad password JhgChsUSmHfac4nL encrypted privilege 0
username Ziad attributes
username Rabih password spWUrnXW1ECf5.vf encrypted privilege 0
username Rabih attributes
username Bassam password Us/9IhMANcKhz/ab encrypted privilege 0
username Bassam attributes
username Peter password DqbletTihLO7nNEm encrypted privilege 0
username Peter attributes
username server password vfxKzw279fclgSJI encrypted privilege 0
username server attributes
username Walid password APoN6.aEe2870Ndh encrypted privilege 0
username Walid attributes
username Walidserver password APoN6.aEe2870Ndh encrypted privilege 0
username Walidserver attributes
username bernard password V/Fqxj2ERUtY84vU encrypted privilege 0
username bernard attributes
username Vanity password 8v6Sr1IM6EXcsg20 encrypted privilege 0
username Vanity attributes
username Hani password 0FhVusN7CyzoUnZ9 encrypted privilege 0
username Hani attributes
username Ahmad password 1Vqu92EEjwYw4N.6 encrypted privilege 0
username Ahmad attributes
username Elias password FEvweu59nheZBOqM encrypted privilege 0
username Elias attributes
username Elie password Dm9wg5M.rlquePYM encrypted privilege 0
username Elie attributes
username Charles password 0mvBLjD9oOlpXvWM encrypted privilege 0
username Charles attributes
username Tony password k1lDmGM/jEHSwgiu encrypted privilege 0
username Tony attributes
username Chadi password x4YJISOa3GY9pG0r encrypted privilege 0
username Chadi attributes
username tonyb password sUb7eW6f55MDItCG encrypted privilege 0
username tonyb attributes
username Tino password onkxSs5qbJYmlepW encrypted privilege 0
username Tino attributes
username Rony password 37Hk2MJVRsiTwC11 encrypted privilege 0
username Rony attributes
username AliA password 4T3JfuTi1E0msmx4 encrypted privilege 0
username AliA attributes
username RonyG password 37Hk2MJVRsiTwC11 encrypted privilege 0
username RonyG attributes
username Aldo password Cq/XUHIHnvc9Ke1x encrypted privilege 0
username Aldo attributes
username Antoine password rJ4Y1txcY1fuURtk encrypted privilege 0
username Antoine attributes
tunnel-group DefaultL2LGroup ipsec-attributes
tunnel-group MGVoice type remote-access
tunnel-group MGVoice general-attributes
address-pool Vocie
default-group-policy MGVoice
tunnel-group MGVoice ipsec-attributes
pre-shared-key *
tunnel-group server type remote-access
tunnel-group server general-attributes
address-pool test
default-group-policy server
tunnel-group server ipsec-attributes
pre-shared-key *
tunnel-group mgvoice type remote-access
tunnel-group mgvoice general-attributes
address-pool Vocie
default-group-policy mgvoice
tunnel-group mgvoice ipsec-attributes
pre-shared-key *
tunnel-group 109.224.18.242 type ipsec-l2l
tunnel-group 109.224.18.242 ipsec-attributes
pre-shared-key *
tunnel-group 81.90.22.188 type ipsec-l2l
tunnel-group 81.90.22.188 ipsec-attributes
pre-shared-key *
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map type inspect im MSNBlock
parameters
match service chat conference file-transfer games voice-chat webcam
  drop-connection log
Cryptochecksum:772d567a5ee1458daec08caad6009da9
: end
Walid Othman Mon, 09/09/2013 - 03:27
I have used the same nat seetings between the ASA 5510 and a 2901 router and it worked just fine.
Markus Thun Mon, 09/09/2013 - 03:31
Ok please check the access rules, for testing use a rule like: permit any any
Walid Othman Mon, 09/09/2013 - 03:41
I have added the permit any any on the outside and vpn interfaces of both ASAs. I also change the source and destination of the nat exempt rule to any any.
