Warning message
ASR 1001 Arp table
Sep 9th, 2013
I have an ASR that is connected to a switch.  Even though there are no devices plugged into the switch, the asr's arp table shows there are.  The arp entries are of devices there have been removed from the switch.  I cannot get rid of these arp entries on the asr.  Am i missing something?
s.marino Mon, 09/09/2013 - 08:26
Did you run the following command:
"clear arp-cache interface" (followed by the interface number)
or
"clear arp-cache" ( followed by the IP Address)
Dmytro Skotnikov Mon, 09/09/2013 - 13:48
  • Cisco Employee,
Hello Jignesh,
Please, share the following outputs from the box in order to get a view of the stale entires.
# show ip arp
or
# show ip arp vrf
Thank you
Best regards,
Dmitry Skotnikov
Jignesh Desai Tue, 09/10/2013 - 06:19
Thanks for the response.  I ended up rebooting the router.  That cleared the arp table.  I did issue the commands in this post, but did not remove the entries.  Will see what happens again.
