09-09-2013 11:05 PM
hi there,
i have cisco sg 300- 28 port switch.
in 28 port why 4 ports are isolated from others..? is there any difference between them...?
Solved! Go to Solution.
09-12-2013 08:39 AM
Hi Sundar, to add to Endless, these ports do not have any specific or special role. You can use them in the same capacity as any other port.
I think what Endless is saying, on the 10/100 switches those are still gig-e ports which can be used as a more efficient uplink port than the 10/100 ports. I also think the same on the gig-e switches since it is easier for labeling.
-Tom
Please mark answered for helpful posts
09-12-2013 07:51 AM
Hi Sunder
These ports are Gigabyte ports (1Gb traffic) and the other's are 100 MB.
In my case I use them to link between two switches and to link Servers that use lot of trafic
Good luck
09-12-2013 08:39 AM
-Tom
