Warning message
Can SG100D-08P provide PoE for SB Pro AP541N?
Sep 10th, 2013
Hi!
I´ve just bought a SG100D-08P to provide PoE for two AP541N in our small business. Will this switch provide enough power over ethernet for these two? Or do I need a bigger switch?
Thanks in advance!
Ingar
Tom Watts Tue, 09/10/2013 - 07:38
  • Green, 3000 points or more
Hi Ingar, it should be able to provide the POE. They're both 802.3af compliant. The switch has 33 watt to dedicate for power which should be sufficient for 4 AP.
-Tom
Please mark answered for helpful posts
