09-10-2013 12:34 PM
Hi Guys,
I have to small fabrics (A and B), each one composed of two 9148, and each pair of 9148 is connected over the WAN over a trunk, for several times during the day both this links (one for fabric A and the other for fabric B) are having near 100% utilization for almost 1hour, during this time I need to check what are the flows using the link...if this was IP I would be using Netflow...Is there any Way I can check this ? Since for now I only have DCNM monitoring the link's and I only have utilization......but I need what flow is causing this .... I'm havin Synchronous replication over this links and I'm suspecting this is the cause of the problem.
Kind regards,
Bruno Fernandes
09-10-2013 01:23 PM
Hi Bruno,
You can use DCNM-SAN to configure FC-FLOWs on the switch for the source/destination pairs using the ISL and monitor using the DCNM Server.
The below link is old, but may help.
See page 2-8 (adobe page 78 of 272) Performance Manager Using Fabric Manager Server (DCNM)
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/cookbook/MDScookbook31.pdf
Viewing Flows (DCNM)
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/dcnm/fundamentals/guide/dcnm/DCNM-SAN-LAN_published/wc.html#wp1339794
David
09-11-2013 01:54 AM
Hi David,
Yes but this requires me to define what flows I wan't to anallyze, I was looking more for something like point to a specific ISL and from there discover what flows are using that ISL, utilization byt flow....
Thank's for your help,
Kind regards,
Bruno Fernandes
12-24-2013 07:28 AM
Will look into this requirement. Meantime we made enhancements to fc flows based on traffic in DCNM 6.2(3)
