09-11-2013 02:34 AM - edited 03-04-2019 09:00 PM
I have network performance issue on my net network with routers and switches and unable find the issue ..
Need suggestions for resolving issues and how to check in Routers and switches in performance issue ,resolution process ?
thanks in advance
09-11-2013 02:56 AM
share the detailed information.....
09-11-2013 04:53 AM
Thanks for reply
My question is users are rasining issues internet runninng slow .
I got a task from senior engg team check network performance in routers and switches ,
I have no idea to check network connectivity performance issues.
Can you pls hel meout
09-11-2013 05:08 AM
do continous ping for google.com and see for any drops and latency (time on the ping reply is higher like 1000 and above).....
and share the results....
09-11-2013 05:21 AM
Here is the result
Pinging google.com [173.194.36.1] with 32 bytes of data:
Reply from 173.194.36.1: bytes=32 time=317ms TTL=55
Reply from 173.194.36.1: bytes=32 time=334ms TTL=55
Reply from 173.194.36.1: bytes=32 time=310ms TTL=55
Reply from 173.194.36.1: bytes=32 time=309ms TTL=55
Ping statistics for 173.194.36.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 309ms, Maximum = 334ms, Average = 317ms
It seems no issue with latency
09-11-2013 05:35 AM
That is a poor latency average - I am guessing that your WAN link is over-utilized.
Please post a "show run" and and a "show interface" from your router.
09-11-2013 05:52 AM
Hi Praveen,
This seems no issues on that....please check the same when you face slowness....
09-11-2013 05:55 AM
Are you kidding me? You think latency of over 300ms is normal? Where do you live? Neptune?
09-11-2013 06:09 AM
Please share the trace route results as well......
09-11-2013 06:11 AM
For Performance issue of Switch, Please share the Show process output
for Slowness of Speed please share the show int summary..
and share the allocated bandwidth for u from service provider..
09-11-2013 10:06 AM
Hi Praveen,
Kindly check the output of "show process cpu sorted" & "show interfaces" from the devices involved when your receive complaints regarding slow browsing. This might help you resolving the issue.
Thanks & Regards,
Vignesh R P
