Warning message
AnyConnect works on one Win7 PC, not on another
Sep 11th, 2013
The computers are at different locations using the same version of AnyConnect (2.5.2014) as I'm trying to connect to my ASA 5505. This connection was once working and now all of a sudden it's not.
The computer that can't connect gives this error:
"AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again."
I have done all options I could find including changing the DisplayName in the Registry (it did not need changed). I also am not running Kaspersky on either computer.
The computer that can successfully connect shows a security prompt from AnyConnect after connecting:
"This page requires a secure connection which includes server authorization"
"The Certificatre Issuer for the site is untrusted or unknown. Do you wish to proceed?"
Can someone please help?
rauno.lehiste Wed, 09/11/2013 - 04:49
Windows service: Internet Connection Sharing (ICS) might cause this problem. Disable it on client
Jeff Rozar Wed, 09/11/2013 - 10:02
ICS is already stopped and service is set to Disabled
Jeff Rozar Thu, 09/12/2013 - 06:58
I get this message on the working Windows 7 computer, and pressing Yes it successfully connects.
But on the computer where it doesn't work, this message *does not* come up. How can I get this message to come up?
If I press No (on the working computer), I get the same dialog that appears on the non-working computer:
Related Content
