crypto map applied to sub interface = partial encryption
Sep 12th, 2013
I have a router on a stick configuration.
With sub interface .1 and .2
I have applied the crypto map to sub interface.2
When I ping across the tunnel replies from the .1 sub interface are encrypted.
But any traffic received from the vlan connected to the sub interface .1 appears to bypass the crypto map and goes across the wan in clear.
FYI main interface is a port channel connect to a stacked switch.
Lei Tian Thu, 09/12/2013 - 20:05
  • Cisco Employee,
This does seem to be right. What software version are you running on the router? Can you also post the config from the router?
HTH,
Lei Tian
martinbuffleo Mon, 09/16/2013 - 05:17
crypto isakmp policy 2
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp policy 3
encr 3des
hash md5
group 2
lifetime 3600
crypto isakmp key password address 0.0.0.0
crypto ipsec transform-set SAL esp-aes 256 esp-md5-hmac
mode tunnel
crypto map VPN 10 ipsec-isakmp
set peer PeerIP
set security-association lifetime seconds 28800
set security-association idle-time 86400
set transform-set SAL
match address 105
interface Port-channel1
no ip address
hold-queue 150 in
interface Port-channel1.69
encapsulation dot1Q 69
ip address IPaddrs.2 255.255.255.0
no ip proxy-arp
standby 1 ip IPaddrs.1
standby 1 timers 1 4
standby 1 priority 105
standby 1 name VLAN69
crypto map VPN redundancy VLAN69
interface Port-channel1.70
encapsulation dot1Q 70
ip address otherNet.2 255.255.255.0
no ip proxy-arp
standby 1 ip otherNet.1
access-list 105 permit ip otherNet.0 0.0.0.255 Branch.0 0.0.0.255
martinbuffleo Mon, 09/16/2013 - 23:09
Cancel that
Turns out my 3rd party VPN device althought it claims to packet capture its wan interface. It doesn't.
Note to self always use span ports or a hub.
