Warning message
Lei Tian Fri, 09/13/2013 - 04:55
  • Cisco Employee,
What field would you like to monitor from flexible netflow? Do you want use netflow to capture IPs and byte count only, like you have from IP accounting?
HTH,
Lei Tian
HTH,
Lei Tian
jakewilson Fri, 09/13/2013 - 05:49
Hi Blackswans,
Lei Tian is correct.  What do you want to collect and export?  If you just want IP addresses and the total bytes. A configuration something like this will work.
!step 1 create the record 'ip-accounting-record'
flow record ip-accounting-record
match ipv4 source address
collect counter bytes
!step 2 create the monitor 'ip-accounting-exporter'
flow monitor ip-accounting-exporter
destination 10.10.10.10
source loopback 0
transport udp 2055
template data timeout 60
!step 3 create the monitor by tying the record to the exporter
flow monitor ip-accounting-monitor
exporter ip-accounting-exporter
cache timeout active 60
!step 4 apply the monitor to each interface
interface fastethernet0/0
ip flow monitor ip-accounting-monitor input
interface fastethernet0/1
interface fastethernet0/2
Then, you will need a good Flexible NetFlow collector.  I recommend Scrutinizer as it can dynamically handle unique templates like this.
Jake
www.NetFlowKnights.com
