Warning message
Problem with login to AP 881GW
Sep 13th, 2013
Hello.
I have problem with login to AP in Cisco 881GW.
I have in running-config default config with memory on flash this router: dir flash: cpc-8xxx.cfg.
I write in EXEC mode:
service-module wlan-ap0 session
then i must put login and password to AP.
I write cisco/cisco and nothing.
I can't get mode AP. Authentic failed.
When i go to web interface I have same problem.
This link:
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/wlan_ps380_TSD_Products_Configuration_Guide_Chapter.html#wp1061918
it doesn't help.
I can't find any answer in this posted threads.
Have you any ideas?
Jacob Snyder Fri, 09/13/2013 - 06:59
  • Bronze, 100 points or more
You have to add a username and password when you first log into the router. I believe the login banner warns you to do this otherwise you will be locked out.
You can factory reset the AP module, but you will lose any config in the AP. The command is:
service-module wlan-ap 0 reset default-config
krzysztofwalczakzg Fri, 09/13/2013 - 13:30
When I first time turn on the router I have:
yourname#
I do reset the AP module and I can't get mode AP. Authentic failed.
When I write:
sh controller wlan-ap0
I have nothing.
It is correct?
Related Content
