Warning message
Need lab recommendation
Endorsed Question
Sep 13th, 2013
I want to get me CCNA Security certification and would like your suggestions for a home lab.  I DO NOT want to use GNS3.  Should I get an ASA too?  I learn from hands on and have about 900 to spend on a lab.
Thank you for your ideas!
Michael
PS: I do not have any equipment yet.
Endorsed by Julio Carvajal
johnlloyd_13 about 3 years 11 months ago
If you have a current CCNA RS lab it will be easier to do an upgrade to CCNA Security.
You'll need a couple of 1841s and 2950 or 2960 switches depending on your budget.
I always check out this site for lab setup/kits:
http://www.certificationkits.com/how-to-ccna-security-lab/
Personally, I've got an ASA 5505, few 1841s, an 8-port 3560 and 2960.
Overall Rating: 5 (1 ratings)
johnlloyd_13 Sat, 09/14/2013 - 07:19
  • Blue, 1500 points or more
