Warning message
command for changing gbic cards on switch
Reza Sharifi Fri, 09/13/2013 - 15:43
  • Cisco Designated VIP,
    2017 LAN
You can replace the card without using any commands.   The cards are hot swapable.
InayathUlla Sharieff Fri, 09/13/2013 - 17:19
  • Cisco Employee,
Reza,
Not sure what exactly is the question...but never the less yes as mentioned by you that we dont have any cmd to replace the card.
But I was thinking is the question beeing asked to change the Gbic from 10G to 1 Gig?
If yes then as you know the below command would do the trick:
#conf t
#hw-module module X port-group gig-interface ( This will convert 10 gig to 1 gig).
Ref:http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/sw_int.html
Inayath
