Warning message
How to configuration Cisco switch connect dhcp server?
Answered Question
Sep 15th, 2013
I have one DHCP server connect to the cisco switch. Port # 47 connect to DHCP server. Port # 48 connect to Dsl modem, Port # 1 to Port # 46 this ports for employees
How to configuration  the switch ?
find  below photo
Correct Answer by Carlo Poggiarelli about 3 years 11 months ago
Hi.
All pc should be also in the same VLAN of DHCP server.
Carlo
Correct Answer by Reza Sharifi about 3 years 11 months ago
If all your PCs are in the same subnet as the DHCP server, you don't need a helper address. The DHCP should assign IPs to hosts (as long as you have the correct scope configured on the DHCP server).
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Sun, 09/15/2013 - 08:03
  • Cisco Designated VIP,
    2017 LAN
Correct Answer
Carlo Poggiarelli Sun, 09/15/2013 - 10:05
  • Green, 3000 points or more
Hi.
Carlo
