09-15-2013 09:08 PM - edited 03-21-2019 07:46 AM
Its possible to establish a Sip trunk with CME in be3000?
09-16-2013 08:13 PM
Test IOS:
c2800nm-adventerprisek9_ivs-mz.151-4.M6.bin
c2800nm-adventerprisek9-mz.124-24.T5.bin
c2800nm-adventerprisek9-mz.124-9.T.bin
CME:
dial-peer voice 100 voip
destination-pattern 6... // Extension number in BE3000 or (destination-pattern 6444) 6444 is AA in BE3000
session protocol sipv2
session target ipv4:192.168.200.253 //BE3000 IP address
dtmf-relay sip-notify
codec g711ulaw
no vad
BE3000:
connect--pstn-- add --sip trunk-CUBE(add CME) next --next --next
http://tools.cisco.com/s2slv2/ViewDocument?docName=EXT-AS-585953
07-07-2014 05:34 PM
Yes you can through a CUBE.
Regards.
09-02-2014 07:08 AM
Hi Emanuel.
I have the same problem connecting 2921 router with CME to a BE3000.
Can you help with configuration needed in the Router in order to enable CUBE and establish a SIP connection between the two?
Thank you.
Danny.
09-02-2014 08:48 AM
Hi Danny,
You can enable CUBE feature with the following commands:
voice service voip
ip address trusted list
ipv4 x.x.x.x y.y.y.y
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 3600 min 3600
I recommend you setup the ip address trusted list to avoid a toll fraud, where x.x.x.x is the ip address from a host or network and y.y.y.y is the subnet mask.
Setup a voice class codec, for example:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
Configure yours outbound and inbound dial peers like these:
description *****Calls to CUCMBE3K*****
destination-pattern 17[4-9].
session target ipv4:z.z.z.z
voice-class codec 1
dtmf-relay h245-alphanumeric rtp-nte sip-notify
ip qos dscp cs3 signaling
incoming called-number .T
no vad
Where z.z.z.z is the IP address from CUCMBE3K
Please rate useful information.
Regards.
09-04-2014 03:41 AM
Hi Emanuel,
Thank U for your reply. I will try to configure the Router with your configuration.
Best regards,
Danny.
07-22-2014 01:30 AM
were you able to establish SIP trunk between them?
When you say "through CUBE", does it mean that i need an additional hardware besides the CME?
Thanks in advance,
Tom.
07-22-2014 04:20 PM
Hi tomgolan88,
A voice router can be CUBE and CME at the same time, but it is recomended that voice router will be a ISR G2 or a ISR with IOS version 15.1 at least,
You can check these information,
http://www.cisco.com/c/en/us/solutions/enterprise/interoperability-portal/networking_solutions_products_genericcontent0900aecd805bd13d.html
Regards.
08-06-2014 01:47 AM
I need to connect CME and BE3000, without CUBE.
Is it possible?
08-06-2014 08:57 AM
Hi dannyg@bynet.co.il,
A CUBE is a requirement to integrate your BE3K, so you have to enable CUBE feature on your CME.
Conclusion, is it possible, what are you CME version and hardware?
Regards.
08-07-2014 03:32 AM
Hi Emmanuel
I have a Cisco 2921 with CME 7.1.
How is that I can establish a SIP Trunk between 2 CMEs without CUBE, and between CME and BE3K I need CUBE?
It won't work without CUBE or this is an unsupported scenario?
Danny
08-07-2014 09:52 AM
Hi dannyg@bynet.co.li,
In Mexico there is only a option to make a SIP Trunk through CUBE, so in my case I could integrate a SIP Provider for PSTN and CME enabling the CUBE feature on ISR.
I recommend you to upgrade the IOS on your 2921 to have at least CME 10.0.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucmbe3k/8_6_3/system/BE3K_BK_C30C50F6_00_cucm-be3000-admin-guide/BE3K_BK_C30C50F6_00_cucm-be3000-admin-guide_chapter_01.html#BE3K_TP_SAEB67BA_00
Regards.
