Warning message
Multilink PPPoE
Sep 15th, 2013
Dear all,
I was wondering is there anyway to configure multilink on ethernet interface? I understand that there is a configuration for Serial interface,which is called Multilink PPP which bundles a few serial interface togehter, but I was wondering do we have the same configuration for Ethernet interface?
Thanks.
cadet alain Mon, 09/16/2013 - 02:27
  • Purple, 4500 points or more
Yes this is called an etherchannel but it is not working exactly the same as multilink PPP but it bundles interfaces and load balances across them.
What do you want to achieve ?
EDIT: ok I just realized you wanted to do PPPoE     I know this is possible but I don't know which platforms support it.
Alain
