router configuration
Answered Question
Sep 16th, 2013
Hi. i saw below statement in my router.  May I know why use this command?
1) why need to boot startup-config from flash instead of NVRam? any advantage?
boot-start-marker
boot config flash:startup-config
boot-end-marker
2) why need to set card type.  If my fastethernet 0/1 is 10M Internet and fastethernet0/0 is local LAN, Interface serial0/0/0:0 is 2M MPLS connection?
card type e1 0 0
Correct Answer by Carlo Poggiarelli about 3 years 11 months ago
Alan.
As I mentioned, that command in needed to let the router know what card type you are going to use with that module.
Without that command you could not see the interface s0/0/0:0
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Overall Rating: 5 (1 ratings)
Carlo Poggiarelli Mon, 09/16/2013 - 02:22
  • Green, 3000 points or more
Hi Alan.
1) Booting from flash has the same result. In flash you can store more config files than in NVRAM in case you should roll back to a prevoious configuration version version
2) To activate E1 Controller you need that command
Carlo
alan-wong Mon, 09/16/2013 - 07:27
For 2. Activate e1 controller. Does it affect the bandwidth on each interface?
Correct Answer
Carlo Poggiarelli Mon, 09/16/2013 - 07:42
Alan.
Carlo
