BGP ipv6 Implementation
Answered Question
Sep 16th, 2013
We started to test dual-stack bgp implementation. although we established neighbour over ipv6, seems still we couldnt advertise our networks on internet and we couldnt reach anywhere over ipv6 address.
Here our related configs and outputs;
router bgp 3xxx
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 2A02:E0:0:xx::1 remote-as 34xxx
neighbor x.x.x.x remote-as 34xxx
neighbor x.x.x.x remote-as 91xx
maximum-paths 4
address-family ipv4
exit-address-family
address-family ipv6
  neighbor 2A02:E0:0:xx::1 activate
  neighbor 2A02:E0:0:xx::1 prefix-list v6in in
  neighbor 2A02:E0:0:xx::1 prefix-list v6out out
  network 2001:67C:xxxx::/48
  no synchronization
exit-address-family
ipv6 prefix-list v6in seq 5 permit ::/0 le 128
ipv6 prefix-list v6out seq 5 permit 2001:67C:xxxx::/48
interface GigabitEthernet0/2
ip address 92.45.xxx.x 255.255.255.252
no ip redirects
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
media-type rj45
negotiation auto
ipv6 address 2A02:E0:0:xx::2/126
ipv6 enable
7200-1_KULE#sh bgp ipv6 unicast
BGP table version is 4, local router ID is 212.156.xx.xx
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> ::/0             2A02:E0:0:xx::1                        0 34xx 34xx 130xx 94xx i
What we supposed to do ?
Best regards.
Correct Answer by Harold Ritter about 3 years 7 months ago
I see you have a network statement in your BGP configuration. Do you have a matching route installed in your local RIB? This is required to originate the route in BGP. Normally, just a static route to null0 is sufficient.
Overall Rating: 5 (1 ratings)
Correct Answer
Harold Ritter Mon, 09/16/2013 - 06:21
  • Cisco Employee,
CSCO11177789 Mon, 09/16/2013 - 07:04
Hello;
As you say i add ;
ipv6 route 2001:67C:xxxx::/48 Null0
statement and working now. Thank you
But why we need this ? I'll be very appreciated if  you explain a little.
In ipv4 bgp we dont use similar statements
Best regards
Harold Ritter Mon, 09/16/2013 - 07:13
  • Cisco Employee,
For BGP to originate a route using the network statement, there needs to be a matching route in the RIB. This also applies to ipv4. Of course, you could use a "redistribute statement" instead but the network statement for the aggregate route with a static route to null0 is part of the best practices.
Harold Ritter Mon, 09/16/2013 - 09:19
  • Cisco Employee,
One more thing. The reason you do not need to have a static route for ipv4 might be that one of the local subnets already matches the network statement you use.
CSCO11177789 Mon, 09/16/2013 - 13:21
Yes, we have three  C class networks and one of them is used for firewall side.
May i ask aother question?
On ipv4 bgp conf. we use route maps for coming and outgoing traffic on 3 different metro ethernet internet connections. We have 3 c class ipv4. so we configured load sharing for each networks between net connections. We use local-pref, weight or as path prepend.
Could we do the same thing for ipv6 connections ? We have ::/48 . for example we want to use ::/56 and share networks on internet lines.
Best regards
Harold Ritter Mon, 09/16/2013 - 19:17
  • Cisco Employee,
The /48 is the longest prefix that ISPs will generally accept. So if you break your /48, it is very unlikely that the longer prefixes will propagate on the Internet. On the other hand, if you do advertise the /48 out to each of your ISPs some load sharing will take place inbound.
Related Content
